Author Topic: small parts-some NOS  (Read 2021 times)
Offline DWhitaker
« on: June 23, 2011, 04:29:48 PM »
I have the following:
1.NOS- in the Ford packaging. 2 pair C7ZZ-15533-A reverse light gaskets. These are the black ones that will need the molding flash trimmed before use. $35. per pair.
2. NOS Magnum 500 center caps. D1ZZ-1130-G. 2 are in the Ford packages, 2 are not. These are for the later style Magnums with a 2 1/8" center hole. $75. set of 4.
3. NOS- in the Ford package C5ZZ-7A533-A firewall clutch rod boot. $25.
4. NOS- in the Ford box carb choke cover and gasket. C6AZ-9848-A $20.
5. NOS- in the Ford box C5ZZ-7D351-A shifter rubber seal for non console automatic trans. cars. $15.
Used:
1. 67-8 Midland brake booster spacer 2 piece set. This goes between the booster and master cylinder. $30.
2. FE 390-427-428 distributor holddown clamp. $10.
3. D00E-8509-A single groove water pump pulley. 7" diameter. 70 429 CJ. $35.
4. 67 disc brake proportioning valve. Mounts in line at rear of car. Has vise grip marks on it and probably needs disassembled and rebuilt. $25.
5. 67 overhead console front mounting bracket. $25.
6. 67 door handle access plugs for deluxe door panels. pair $20.
7. 67-8 big block upper radiator mounting bracket. $30.
8. 69-70 big block upper radiator mounting bracket $30.
9. 65-6 power steering dipstick $20.
10. 67 rear ashtray for console. nice shape. $35.
11. 67 original pcv valve marked C7AE-6A666-C valve inside moves freely. $25.
12. 67 original pcv valve marked C7AE-6A666-A and Eaton. This one has a snap ring on the bottom where it can be disassembled. Valve moves freely. $25.
All prices include shipping in the US. PM me if interested. Thanks for looking.
« Last Edit: June 23, 2011, 09:43:30 PM by DWhitaker »
Offline janschutz
Re: small parts-some NOS
« Reply #1 on: June 23, 2011, 06:48:35 PM »
I need the 67-8 Midland brake booster spacer 2 piece set. This goes between the booster and master cylinder.,
how do I send payment?
Offline DWhitaker
« Reply #2 on: June 23, 2011, 09:34:32 PM »
janschutz,
PM sent. Thanks.
