Author Topic: choke cable question  (Read 1574 times)
Offline dbm350
« on: June 23, 2011, 11:09:01 AM »
        I'm working on a 66 SJ K code fastback. Mid April build.  What is the correct fastener to attach the bracket to the dash. Size, finish ,etc.   Also, where the cable attaches to the carb, how much of the coiled metal covering is exposed coming out of the rubber sheath.   Thanks,  Doug
Re: choke cable question
« Reply #1 on: June 23, 2011, 02:44:49 PM »
Believe the assembly manual calls this out, but what I have found is a somewhat flattened hex bolt with an attaching nut that has a captured tooth washer or a lock washer.
Offline 66kcoupe
« Reply #2 on: June 23, 2011, 06:37:53 PM »
I don't know if this helps you or not but here is a pic of my early April Metuchen K code choke cable.
1966 Mustang Hipo Coupe, in the family since new (unrestored)
1991 Mustang LX 5.0 Notchback (daily driver)
Offline dbm350
« Reply #3 on: June 23, 2011, 11:59:27 PM »
       Thanks to both of you. Just the info I needed. When you buy a car that already completely disassembled and put it together, there are alot of detail questions that arise. Thanks , Doug
