Author Topic: 1966 Sprint 200  (Read 10892 times)
Offline jgidley12
Re: 1966 Sprint 200
« Reply #15 on: June 25, 2011, 11:09:13 AM »
Thanks...I just sent him a message.
Offline jgidley12
Re: 1966 Sprint 200
« Reply #16 on: July 13, 2011, 06:31:10 PM »
Finally went out and removed the chrome air cleaner on the car and I searched all over it, the snorkel and the base and could not find any date codes or dates anywhere on this item. Just thought I should add that here since a previous respondent indicated that there should be a date code on either the base or the underside of the snorkel. So...should I just sand this one down and repaint it or keep looking for a decent original used one to repaint? Let me know your thoughts anyone.
Offline Pete Bush
Re: 1966 Sprint 200
« Reply #17 on: July 13, 2011, 10:10:11 PM »
I don't know what to tell you. I know my Sprint air cleaner had a date code on the underside of the base of 6C
Offline jgidley12
Re: 1966 Sprint 200
« Reply #18 on: July 13, 2011, 10:18:43 PM »
My car has a June 1966 build date code. If it originally came without a snorkel how do those breath? I just want it to be original...what should I do? I believe that someone here suggested that the air cleaner without snorkel came late in 1966 and were used exclusivly on the 1967 six cylinders.
Offline Twilight65
  • Gold Level Subscriber
Re: 1966 Sprint 200
« Reply #19 on: July 14, 2011, 12:46:51 AM »
Here's a picture of my May 66 Sprint Air Cleaner from the bottom. Date stamped "6E" (May 1966). No snorkel. There is a gap all the way around between the bottom plate and the chrome top that air is drawn through to the carb.
Dave
Offline Pete Bush
Re: 1966 Sprint 200
« Reply #20 on: July 14, 2011, 06:30:46 AM »
My air cleaner has no snorkel and the stamp location is identical to Dave's.
In the center where the base sits on the carb, there's a rubber gasket that fits down in the groove in the base. Only mention this because Dave's seems to be missing in his picture. And then there's a plastic fitting that sits on the carb before the air cleaner bolts onto it.
Offline Twilight65
Re: 1966 Sprint 200
« Reply #21 on: July 14, 2011, 07:19:29 AM »
Not to hijack the thread too much but question for Pete. I have the rubber gasket but do not have the plastic fitting. Do you have a picture? For jgidley12 I think as far as what you should do depends on what level you are trying to get your car too. Seems the air cleaner you have could easily be cleaned and painted. If later you are trying to get more correct with dated one you would a least have a freshly painted one that presented well while you are looking.
Dave
« Last Edit: July 14, 2011, 09:08:09 AM by Twilight65 »
Offline Pete Bush
Re: 1966 Sprint 200
« Reply #22 on: July 14, 2011, 08:42:52 AM »
Here's some pictures for you Dave...
Offline Twilight65
Re: 1966 Sprint 200
« Reply #23 on: July 14, 2011, 09:10:15 AM »
Thanks for the pictures Pete, Now I will have to find one as mine is missing.
Dave
Offline jgidley12
Re: 1966 Sprint 200
« Reply #24 on: July 15, 2011, 12:05:12 AM »
I just want my car to be correct. My air cleaner is obviously correct for the fit although I do not think it is correct for  the fact that it has been chromed. But why does it not have a date code on it anywhere!!!!!
Should I just sandblast this air cleaner and paint it the correct Ford Dark Blue or should I look for an air cleaner that does not have the snorkel to be correct for a June 1966 Dearborn mustang? What are ;your thoughts please. Johnnie
Offline kevin1221
Re: 1966 Sprint 200
« Reply #25 on: July 15, 2011, 06:43:46 AM »
My '66 Dearborn built Sprint has a scheduled build date of July 7, 1966. The chrome air cleaner does not have a snorkel.
Kevin
Kevin
Tampa FL
1966 Mustang Sprint 200ci Six - Automatic
Scheduled Build date : 7-7-66 - Dearborn
MCA Concourse Gold winner (Multiple)
MCA Conservator Award
AACA Sr Grand National 1st (Repeat)
Currently own 2008 Shelby GT
Offline Pete Bush
Re: 1966 Sprint 200
« Reply #26 on: July 15, 2011, 06:49:47 AM »
Johnnie,
Since you're asking this question on a Concours Forum, and prefacing it with a statement like "I just want my car to be correct.", I'd venture to say that the issue was important enough to you to try to find a period correct air cleaner. That being said, the issue of whether a correct air cleaner for your car should have a snorkel or not is a little more difficult to answer. Based upon the limited amount of Sprint owners that participate on this forum and the date of your car, an air cleaner without a snorkel is the probable choice. But Ford in those years rarely did anything in a cut and dry manner, and there are allot of Sprints and 6-cylinders unaccounted for if we merely poll the participants here. We may find that snorkels were used in some instances.
I think Dave's suggestion is probably a good one: Paint the air cleaner you have, and keep your eyes out for  a dated base. Or you may attempt to reproduce the stamp in the base, and just keep the whole thing. Sorry if this is a vague response, but there's no way to advise you differently without researching the thousands of 6-cylinder cars built in '66. Keep what you have and begin noting what you see a car shows. Talk to Tony Kovar who runs the Sprint registry. He may provide a little deeper understanding from his personal forensic experience. I think it was his comment about the late model year change over that you're referring to. Just be prepared that there may never be a hard fast rule....
Offline jgidley12
Re: 1966 Sprint 200
« Reply #27 on: July 15, 2011, 02:19:58 PM »
Thanks guys for all your responses. They are all taken sincerely to heart. 'till next time-Johnnie
Offline NEFaurora
Re: 1966 Sprint 200
« Reply #28 on: July 18, 2011, 03:49:58 AM »
Interesting, I've never seen one of those Plastic fittings.  I've always seen the rubber gaskets that are normally there.  I wonder if that may have been sporatically Plant Specific...Again, Interesting.
The snorkel on the I-6 air cleaners were dropped in Early 1966 in favor of the cheaper non-snorkel type. It looks like the snorkel was dropped somewhere around April to May 1966. Never seen an original snorkel air cleaner on a post May '66 car..
Tony K.
MCA#70001
Re: 1966 Sprint 200
« Reply #29 on: July 18, 2011, 10:36:13 PM »
If there was no snorkel, how did the air get into the carb?
Sorry for the seemingly dumb question, but without good pics of the entire assembly, I'm somewhat at a loss here, fellas...
