Author Topic: Front drum brake question  (Read 8381 times)
Re: Front drum brake question
« Reply #15 on: October 13, 2016, 10:37:54 PM »
CHARLES/JEFF.
image from a unrestored v8 late 66 Dearborn mustang with drum brakes.
Question remains if he was looking for 65- 66- 67-68-69-70-71....... ?  details - Lots of years and variations.
« Last Edit: October 13, 2016, 10:40:06 PM by J_Speegle »
« Reply #16 on: October 13, 2016, 10:52:17 PM »
Charles, would this hold true for Oct 64 as well?
Well, I couldn't say for sure.  Appears the foam was used on both.
Offline Scott302
« Reply #17 on: October 14, 2016, 01:21:54 PM »
Charles,
Forgot that this was from my Metuchen '66. Not sure of the build date.  Ser# 1853XX.
Regards,
Scott
Scott, what assembly plant was the foam gasket on a V8 found?  I disassembled 3 '65 San Jose cars, all built in late January/early February.  The V8's had the flat gasket and the I6 had the foam.
Scott Halseth
Ford Product Manager
National Parts Depot
MCA#01776
Offline ChrisV289
« Reply #18 on: January 10, 2017, 03:06:06 PM »
Anyone know what the thickness of this material is? NPD isn't sure when they are getting a supply in and thought I would just get a sheet of cork material.  Comes in either 1/16 or 1/8 thickness.
2009 V6 Mustang Coupe
« Reply #19 on: January 10, 2017, 03:14:20 PM »
Believe its the 1 /16. That is the one I would use
Offline ChrisV289
« Reply #20 on: January 10, 2017, 03:37:25 PM »
Thanks Jeff!
Offline ChrisV289
« Reply #21 on: January 14, 2017, 02:41:00 PM »
Was able to separate it from the backing plate. Appears to be cork. Oct 29 64 build V8.
