Author Topic: 68 FE bolts for Brackets  (Read 4973 times)
Offline TLea
Re: 68 FE bolts for Brackets
« Reply #15 on: June 23, 2011, 09:39:01 PM »
Its a 4 speed car but honestly I can't remember which hole is which. I probably just stuck a bolt in there and figured out which hole after.
Offline 68 S Code
« Reply #16 on: June 23, 2011, 11:09:35 PM »
Well the dipstick bracket on the C6 lines up perfectly with that hole. Frankly so does the grounding strap. I'm going to mount both with the one bolt. Only question I have is do I use the ZD place bolt or a phosphate RBW bolt?
