Author Topic: 66 under-dash A/C fasteners  (Read 2617 times)
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« on: June 18, 2011, 03:24:35 PM »
Does someone have a picure of the fasteners that attach the 2 mounting brackets onto the fiberglass A/C housing?
The brackets that bolt the unit to the underside of the dash.  Mine is riveted to the case with HUGE pop-rivets and I'm sure that's wrong.
66 Metuch Conv
Nightmist, Std Blu Int
Offline ChrisV289
Re: 66 under-dash A/C fasteners
« Reply #1 on: June 18, 2011, 06:59:07 PM »
It's a little warm in the garage right now...(It's 108 outside alone)...I can try and take a picture either late tonight or early tomorrow before the sun rises....I assume 65 and 66 would be the same...
2009 V6 Mustang Coupe
Offline bryancobb
  • 2009 Ridn' Around
« Reply #2 on: June 19, 2011, 08:57:42 AM »
Thans Chris,
I don't know for sure, but I'll bet 65's and 66's have a different attachment method because the brackets and the body itself are different.
I'm going on a web search for pictures.
66 Metuch Conv
Offline ChrisV289
« Reply #3 on: June 19, 2011, 09:26:09 AM »
Bryan,
I took these this morning...I hope they help...My camera isn't the greatest when it comes to close ups of the bolts...Maybe someone has better pictures...Pay no attention to the dirt/dust behind the curtain...I don't think it's ever been really cleaned behind there in the 19 years the car was owned by my dad...Plus it gets dusty our here in AZ...
Offline bryancobb
  • 2009 Ridn' Around
« Reply #4 on: June 19, 2011, 01:32:46 PM »
Thanks for going to the trouble, Chris.  ;D
66 Metuch Conv
« Reply #5 on: June 19, 2011, 04:07:24 PM »
The fasteners in the pic that attach the unit to the dash do not appear to be right.  Those are typically a phosphate bolt with a captured tooth washer, large tooth-style.  AMK has these in their catalog.  I don't recall if there is a difference between 65 and 66, but most likely is not.
Offline bryancobb
  • 2009 Ridn' Around
« Reply #6 on: June 19, 2011, 08:45:06 PM »
Charles,
I have the AMK kit that bolts the unit under the dash.
What I am needing is the fasteners that attach the two brackets to the fiberglass housing.
66 Metuch Conv
Offline ChrisV289
« Reply #7 on: June 19, 2011, 09:09:06 PM »
Charles,
Can you post a pic of those bolts that attach to the dash....I just noticed the one on the driver side is different than the one in the pic on the passenger side...
Offline bryancobb
  • 2009 Ridn' Around
« Reply #8 on: June 19, 2011, 09:46:39 PM »
Wiil Do Chris.  Right now.
Here my friend.
« Last Edit: June 19, 2011, 10:11:23 PM by bryancobb »
66 Metuch Conv
