Author Topic: 1967 Dearborn 390 non GT 39,000 miles  (Read 8245 times)
Offline rodster
« on: June 15, 2011, 11:50:02 PM »
From my 39,000 mile 1967 390 non-GT, no AC, Dearborn car.
Could this be an original belt and is the 466 a build date?  Where is the best place to look for a build sheet. I checked under the front seats but haven't looked under the backseat yet.
« Last Edit: January 05, 2015, 11:42:58 PM by J_Speegle »
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
Re: 1967 390 non GT 39,000 miles
« Reply #1 on: June 16, 2011, 12:57:36 AM »
466 would be 4th quarter, 1966, so legit for a '67 production year car.
About the only place you might find a build sheet might be under the carpet.  Or, possibly one stuffed somewhere.
Offline rodster
« Reply #2 on: June 16, 2011, 09:00:35 AM »
Thanks Charles,
Build date for the car is Feb 7, 67 so belt wasn't too old.
I'll look around for the build sheet in the easy spots first. Maybe I'll get lucky.
1984 SVO - 2A
Offline rodster
« Reply #3 on: June 16, 2011, 09:07:56 AM »
Have you ever seen a paper tag on the rear axle of  67 Dearborn car?
Looks like it might be a series of 5's but hard to tell. Not sure of the best way to clean this without ruining it?
1984 SVO - 2A
« Reply #4 on: June 17, 2011, 01:31:54 AM »
Yes, most all axles from back then were supposed to have an identification tag.  Guess it was easier than reading the metal tag for quick identification/application.
« Reply #5 on: June 20, 2011, 07:36:38 PM »
Not on that specific application but on others. Pattern includes identification numbers and such as well as a repeating pattern of what looks to be dots but they are small geometric symbols instead. Numbers and letters are printed not all in a straight line and different colored paper was used depending on year and application it appears.
Jack Brooks has some for specific applications but not all years or applications.
Might remove it and just keep it in a binder with the other car findings. Would use the wax and silicon remover treatment as mentioned before to clean buildsheets.
Nice find
Offline rodster
« Reply #6 on: August 14, 2011, 10:54:58 PM »
Jeff,
Thanks for the info....I'll look up the wax and silicon remover treatment method you mention and give it a try when I get a chance. Here's a close up of the tag as it is and it looks to me to be some 5's?  I'll be curious to see what I find and if any color still exists.
1984 SVO - 2A
Offline rodster
« Reply #7 on: August 14, 2011, 11:16:17 PM »
I removed some old oil build up on the DS head and found this. Appears to be a '12' in a circle.  Common marking?
1984 SVO - 2A
« Reply #8 on: August 16, 2011, 12:23:14 AM »
Haven't seen that particular one yet but it fits patterns I've seen before at that engine plant
Offline 68 S Code
« Reply #9 on: August 16, 2011, 01:11:29 AM »
Intresting close-up in that the head and oil dipstick tube retained blue engine paint but the block looks to be bare metal in the area shown. Did heat just burn it up?
Offline 68 S Code
« Reply #10 on: August 16, 2011, 01:13:34 AM »
Does anyone know what the code would be on the paper tag for a 68 3.25 traction loc rear end?
Offline TLea
« Reply #11 on: August 16, 2011, 10:44:19 AM »
I'm pretty sure you don't have the build sheet, do you have the axle tag? Is it a WES G?
Offline rodster
« Reply #12 on: August 17, 2011, 10:46:00 PM »
Good point... I was focused on the head and didn't pay much attention to the block. When I get a chance I'll clean up the block some more and look for traces of paint.
So much much dirt and grease, so little time.  ;D
1984 SVO - 2A
Offline rodster
« Reply #13 on: August 17, 2011, 11:01:50 PM »
I figured the battery L bracket was long gone but found it, and the hardware, stashed in the console.  8)
1984 SVO - 2A
Offline rodster
« Reply #14 on: October 10, 2011, 11:38:54 PM »
Does this indicate the car came with a GOODYEAR spare tire?
1984 SVO - 2A
