Author Topic: Tubular Crossmember  (Read 1443 times)
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
Tubular Crossmember
« on: June 15, 2011, 12:35:05 PM »
The tubular crossmember that bolts in under the oil pan has a rectangular flat spot
that is approximately 2"x1.25" formed into it.  Does this flat spot go toward the front of the
car or the rear of the car?
It looks like it's purpose is to keep the power steering valve assy. from hitting the tube?
66 Metuch Conv
Nightmist, Std Blu Int
Re: Tubular Crossmember
« Reply #1 on: June 15, 2011, 12:38:21 PM »
you are correct about the flat spot. i have seen a lot of them installed incorrectly.
Offline bryancobb
  • 2009 Ridn' Around
« Reply #2 on: June 15, 2011, 12:44:30 PM »
66 Metuch Conv
« Reply #3 on: June 15, 2011, 11:25:29 PM »
+1. to be installed with the notch ,flat spot etc. on the driver side for P/S equipment clearance if so installed. Bob
Offline 66RavenGTCoupe
« Reply #4 on: December 16, 2013, 06:07:51 PM »
Exactly what I was looking for guys. Didn't even know the flat spot was there until I removed the crossmember. Originally thought it may have been a "jacking" mark or something until I inspected it closely.
66 Metuchen, NJ  GT Coupe
Raven, Deluxe Black Int
6T07A1612##
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRANS
    65B     A      66           02M     22          1     6
Buck Tag:
C/O  362  (Customer Order, Rotation Number)
5    M7 (Weld Bay 5, Bucked Dec 7)
PIO (Performance Image Option - GT)
