Author Topic: 64.5 Convertible Wheel size  (Read 273 times)
Offline Corey Bowcutt
« on: April 23, 2025, 06:15:38 PM »
I just had the 40 year old tires removed from the steel rims that came with my project 64.5 convertible.  I was surprised that two rims measure 15' X 6" and two measure 15" X 7".  What size rims would have originally come with this car?
Corey
Re: 64.5 Convertible Wheel size
« Reply #1 on: April 23, 2025, 07:10:57 PM »
a lot depends on the build date & engine size which you did not specify. more info is necessary for an accurate answer.
« Reply #2 on: April 23, 2025, 08:10:00 PM »
May 12 build date. 260 engine
Online jwc66k
« Reply #3 on: April 23, 2025, 08:22:25 PM »
Not a common option, and with a 260, even more "rare". That's not saying a dealer might have installed 15 inch wheels, but without a window sticker - nope.
« Reply #4 on: April 23, 2025, 08:50:17 PM »
What I am trying to figure out is what size wheels was it supposed to have?
« Reply #5 on: April 23, 2025, 09:32:27 PM »
it could have had 13 or 14" wheels. some early V-8 cars had the 13's. i never knew why unless they were using up parts. for your application i would go with 14 x 5.
« Reply #6 on: April 25, 2025, 06:19:53 PM »
I am realizing I have no idea how to measure wheels.  I was measuring the outer diameter at 15".  The tires that came off the car are 14" so I am figuring you do not measure the largest outside diameter.  Now I am wondering what width dimension you use.  the 6 and 7 " I was measuring were to the outside.  Is the actual measurement to the inside of the lip?
Corey
Online jwc66k
« Reply #7 on: April 25, 2025, 07:35:55 PM »
Yes. And even that can get confusing.
« Reply #8 on: Today at 12:42:57 AM »
A web search should pull up lots of references of how to measure a wheel properly.
