Author Topic: Headlights  (Read 1706 times)
Offline ChrisV289
Headlights
« on: June 13, 2011, 12:31:19 AM »
I'm sure I've probably asked this question before but it's starting to happen again and not sure why.  While I am driving, my headlights randomly go on and off...I replaced the headlight switch about a year and a half ago.  The original one was still in there after 40+ years.  Could the new switch be going bad already?  Is there anything else I should look for or change on the car to correct this problem?  Doesn't do it every time I drive the car...
2009 V6 Mustang Coupe
Re: Headlights
« Reply #1 on: June 13, 2011, 10:39:40 AM »
It could be the switch, although there are a number of other things that can cause it... such as bad grounds to the chassis, repro voltage regulator, etc..
Offline ChrisV289
Re: Headlights
« Reply #2 on: June 13, 2011, 10:51:58 AM »
Hmm...I just put a replacement voltage regulator in the car..the old style...since the one that was in there was going bad and causing the alt light to flicker on and off.  It was a voltage regulator for a 73 Mustang (just changed the top cover) that was in there for a couple of years now.  Guess I'll change it again...See if that cures it.  Thanks Charles...
Re: Headlights
« Reply #3 on: June 13, 2011, 10:17:38 PM »
Flickering on and off of the headlamps is usually due to a bad high beam switch on the floor board, believe it or not!
Re: Headlights
« Reply #4 on: June 13, 2011, 10:54:40 PM »
Definitely would check that too!
Offline ChrisV289
Re: Headlights
« Reply #5 on: June 13, 2011, 11:34:45 PM »
Yeah I know the high beam switch in there is also original....It has a FOMOCO script on one of the plug spades...Charles, I saw the K-code conv had block lettering according to your 08/17/09 posting on your blog...Is this another variety?  I haven't been able to find a replacement on ebay yet...
Re: Headlights
« Reply #6 on: June 14, 2011, 10:25:42 AM »
The block FoMoCo was what I was finding on San Jose cars from that time period.  There was some variance in style/markings.
Offline ChrisV289
Re: Headlights
« Reply #7 on: June 14, 2011, 06:11:46 PM »
If you want to add this one to your catalog for SJ cars from Oct of 64.
