Makes sense Bob I appreciate the input. I was told to take the red wire for the Pertronix off the coil and put it directly to the battery power to see if the tach then would work when starting. The car would start but the tach still didn't work. That's kind of the same thing here isn't it with putting in a wire to the ignition 12v to make it work? It was just a test doing it that way but it didn't work so it again sounds like the tach itself?Chad
Ok I will do that. Is there a specific wire(color) in the ignition just outside of the ignition switch that should be used to tap into for this ? I am wondering if having it converted to the 3 wire set up would eliminate this issue ??
