Author Topic: 1970 trans cross member question  (Read 498 times)
Offline DaveF
« on: March 31, 2025, 06:28:08 PM »
I?m a little confused. The transmission cross member in my 428 SCJ seems to have a fitment issue. The space to fit over the trans tunnel bracing is 3?. The trans tunnel bracing is only 2-1/2?, requiring 1/4? shim washers on either side. I have a big block ?68 Cougar that has a 3? trans tunnel bracing, and everything fits as you would expect. Any ideas are appreciated.
« Last Edit: March 31, 2025, 06:53:57 PM by carlite65 »
1970 Mustang Mach One
428 SCJ w/Drag Pak 3.91
Metuchen plant
Built 9/5/1969
Re: 1970 trans cross member question
« Reply #1 on: March 31, 2025, 11:11:13 PM »
Would guess that over the years someone has forced it and in turn bent it. Plenty of opportunities to hammer one of these in place. Guess you have tried but you can't bring the ends in by tightening the attachment bolts enough
Is it over three inches on both ends or only one. Just trying to help by being a sounding board in this current situation
Offline DaveF
« Reply #2 on: April 01, 2025, 12:12:39 AM »
It seems odd to me. I don?t think that anything has been pounded out of shape. I believe that the cross member on my big block Cougar measures 3? across like this one does. The only difference is that the mounting surface that goes around the transmission tunnel and provides a mounting surface for the cross member, is only about 2-1/2? across, leaving about a half inch gap.
Metuchen plant
Built 9/5/1969
« Reply #3 on: April 01, 2025, 01:14:47 PM »
Doesn't make sense (would not be the first time) that the cross member attached to the floor would be different on a Cougar and a Mustang. Wish I had one of each - or either at home to measure real quickly for the discussion. With how popular both cars are one would think that we would have heard similar reports on the forums over the past 40 or so years.
Lets see what others have found
Offline DaveF
« Reply #4 on: April 02, 2025, 10:44:36 PM »
It's Weird, almost like the tunnel bracing in the Mustang is too narrow.
Metuchen plant
Built 9/5/1969
