Author Topic: 1970 Power Steering LIne Retainer/Clip  (Read 492 times)
« on: March 22, 2025, 01:39:13 PM »
Admin Note: the following eight replies were originally attached to a wanted ads and have been separated and placed in this section so the conversation can continue without drawing attention away from the wanted ad originally attached to.
This is the picture posted in the original first post for context
From what I've seen this clip applies to PS on 351C cars and Boss 302s in 1970.
The PS pumps and brackets are different than Windsors or BBF.
If it fits anything else I'd like to know.
« Last Edit: March 24, 2025, 07:18:25 PM by J_Speegle »
Re: 1970 Power Steering LIne Retainer/Clip
« Reply #1 on: March 22, 2025, 06:48:08 PM »
The clip looks like the one in the "1970 Mustang Chassis Assembly Manual" (AM0035) page 80, lower right hand corner, which has a Ford engineering part number of D0OA-3E506-A (note - number "0" and letter "O") . It does not appear to have any attaching hardware (like a screw).
Applications are Mustang and Cougar with 351W engines.
« Last Edit: March 22, 2025, 06:50:24 PM by jwc66k »
« Reply #2 on: March 22, 2025, 09:34:00 PM »
I think you mean 351C? [edit -- guess not]
The pump bracket is very different on 351W v. 351C because of the location of the pressure port.
The can, 3A674, is very different for the same reason.
The high side hose is also different due to the larger size of the outlet port and length difference where the two tubes converge.
I see the same picture was used for both installations but that's not right.
Can any of the 351W guys verify this clamp is used on both?
Page 81 is the 351C installation.
« Last Edit: March 22, 2025, 09:52:06 PM by Bossbill »
« Reply #3 on: March 22, 2025, 11:02:53 PM »
For 1970 the F, G, H, and M code power steering stuff is the same, except that the 302 and 351W engines, each, have a different front adjusting bracket. Both engines use the same pump and pump mounting brackets.
The 428CJ, and I believe 6 cylinders still used the 1967-69 pump and aluminum pump mounting brackets. I could be wrong on the 6 cylinder engines though.
« Last Edit: March 22, 2025, 11:56:18 PM by krelboyne »
Offline DougDyar
« Reply #4 on: March 23, 2025, 01:09:26 PM »
Are we sure all the small block '70 power steering stuff are the same? I know that on my G code BOSS, the pump mounting bracket that bolts to the pump has a slightly different shape where the hose attaches on the rear, the outlet hose has a different fitting, and the return pipe nipple faces a different direction.
0F02G203277
June 22, 1970 Dearborn BOSS 302
« Reply #5 on: March 23, 2025, 05:04:40 PM »
I see where I neglected to turn the page in the 70 Chassis Manual. The same "clip" is also used on 351 C engines.
The attached picture is what I found in my odds and ends box. It was soaked in old carb cleaner to remove paint and crud, tumbled in brake shoe filings to remove any rust and sprayed with WD-40 as a preservative.
There's one on e-bay for $49 plus shipping. I think I can "beat" that price.
If interested, send me a PM.
« Reply #6 on: March 24, 2025, 02:04:46 PM »
Right. The pump bracket is different, the can and inside pump is offset, the outlet fitting is much bigger and the hose is different. The 70 PS drag link is also different than the other years. It is larger in diameter than even the 69 drag link.
I chronicled all of that here:
https://www.concoursmustang.com/forum/index.php?topic=22112.msg138915#msg138915
« Reply #7 on: March 24, 2025, 04:49:11 PM »
Bill, after approximately April 1/69  1969 production Boss Mustangs and Shelby's with heavy duty suspension which were typically cars equipped with the wider F6015 tires all got the larger tie rod ends which required different draglink and spindles.
« Reply #8 on: March 24, 2025, 06:54:58 PM »
I gather both manual and PS got bigger then ?
I had a heck of a time finding the larger drag link ...
Thanks, Bob.
[I did ask Jeff/Charles to pull out the comments and post all this data to a new thread]
« Last Edit: March 24, 2025, 06:57:47 PM by Bossbill »
Re: 1970 Power Steering Line Retainer/Clip
« Reply #9 on: March 24, 2025, 07:21:02 PM »
Thanks, Bob.
I am admittedly not well versed on 1970 differences however I think most if not all 1970 Mustangs changed over to the larger tie rods so the donor pool should be comparatively large.
« Last Edit: March 24, 2025, 07:40:32 PM by J_Speegle »
« Reply #10 on: March 24, 2025, 07:26:41 PM »
Separated  ;)
Offline Wills70
« Reply #11 on: March 26, 2025, 06:46:07 PM »
I have noticed there is a hole in some clips and not in the the one I have , would this just be a vendor variance , or revision change , assembly plant difference ?
Thanks Will
