Author Topic: 67 interior paint, 2B  (Read 789 times)
Offline 68 GT
« on: March 20, 2025, 10:42:39 PM »
The exterior of our 67 coupe is finally painted! Brittany Blue. The interior is to be 2B. Our body man painted all of the interior, except the dash, Brittany Blue. He did this just to seal everything up. Question is, what all needs to be painted for a 2B interior?
Steering column - Light Blue
Interior textured part of the doors - Light Blue
The textured quarter panel trim - Light Blue
Dash - Light Blue
A pillars? They will have the A pillar pads installed - Light Blue
The 2 lower dash moldings at the windshield - Dark blue
Package tray behind the rear seat - Dark Blue
Do those look correct?
What else am I missing?
What paint codes do I need to supply him? Are the codes Ditzler Light Blue Poly 13004 & Ditzler Dark Blue Poly 13056?
Thank you for your assistance!!
VIN 7T01C246XXX
Actual build date 5-11-67
VIN 8F01J208XXX
Actual build date 6-27-68
Re: 67 interior paint, 2B
« Reply #1 on: March 21, 2025, 08:25:33 PM »
Here is a collection of unrestored 67 2B interiors to help with making your choices
Offline 68 GT
« Reply #2 on: March 22, 2025, 03:24:02 PM »
Thank you Jeff for the pictures. After looking at the pictures you sent, I believe the items I had mentioned are all correct as far as what is painted light and dark blue. I don?t think I missed anything. Just have to get the correct paint codes to the body man so he can order the 2 correct colors of blue for our 67 2B coupe!! Won?t need much of the dark blue at all! And probably a quart will be enough of the dark blue.
VIN 7T01C246XXX
VIN 8F01J208XXX
Offline 68 GT
« Reply #3 on: March 23, 2025, 04:22:24 PM »
Any guidance for ensuring I get the correct paints codes for the 67 2B interior? Are Ditzler codes 13004 and 13056 indeed correct?
Thank you!
VIN 7T01C246XXX
VIN 8F01J208XXX
« Reply #4 on: March 23, 2025, 11:23:36 PM »
Thank you!
Might want to check the Library, look under 1967 and then article titled ' Paint Codes, 1967 Interior & Exterior "Look at page 2 and you will find the original part numbers I think your looking for. Sorry the scan is a poor one but can numbers still be read
« Reply #5 on: March 24, 2025, 08:05:55 AM »
Ford codes attached
Offline 68 GT
« Reply #6 on: March 24, 2025, 06:46:07 PM »
Thanks Jeff and John. I went to the library and found the interior codes for a 67. I found Ditzler 13004 light blue poly & Ditzler 13056 for dark blue poly. I tried to research/cross reference the Ford codes John sent. I can?t figure out what Ditzler or PPG number they cross to. I guess the 2 Ditzler codes, 13004 & 13056, will work for our body man?
Thank you for your help and patience.
VIN 7T01C246XXX
VIN 8F01J208XXX
« Reply #7 on: March 24, 2025, 06:56:36 PM »
Consider that the scan of the MPC is the Ford number for the rattle can , if someone wanted to purchase the paint in that easy use form, rather than paint color code
Offline 68 GT
« Reply #8 on: March 24, 2025, 07:04:45 PM »
Ah, thank you! I?ll give the body man the 2 Ditzler numbers, 13004 & 13056.
VIN 7T01C246XXX
VIN 8F01J208XXX
