Yes I read hundreds of different posts about this and seeing that most say colors are the same for auto and manual trans. So at this point I just want to have at least 2 examples of 67 289 dearborn any transmission.
Not sure where your getting your information from but those reporting that the markings for both manual and automatic 289s would be the same are wrong. As you can see the cropped build sheet drive line and transmission sections Ford shows that they were not. If they were then they would have been identified by the same number and you can see that the automatic does not match the manual ones. If it were my car I would also be concerned that if you apply the wrong markings you would get a deduction at a show and might miss lead others with similar cars.
3 speed - Automatic - 4 speed (shown top to bottom)
For complete disclosure there was a TSB printed that stated that both automatic and manual drive lines were the same. But they list a set of colors used on 67 automatic drive lines that we have pictures of and reports of. Since this directly conflicks with what the workers sued to build the car the TSB may be referring to replacement drive lines and that one could be used as a replacement in both applications. Will have to dig that TSB out and reread it
Did look into another set of files from reports of paint markings from owners. This means that it was their observations alone with no pictures to document the finding so its up to you if you choose to trust them. Only a single observation from a 289 3 speed Dearborn Mustang built sometime in March
He lists them in two groups
At approximately 2/3rds from the front - 3 color lines perhaps white/gray (most likely white just dirty since they didn't use gray form these application during this period), green, yellow
2 thin lines in the rear (Appears white/gray - Same note as above) the usual ? wide, maybe an 1" apart.
He didn't share what color green it was since there are a number that were available and used during 67
Note: These are not the same colors as used on automatic 289's in 67 supporting my statement in the first part of the post
