Author Topic: 68 - 70 two piece rotor set  (Read 402 times)
Offline kgranhold
« on: March 06, 2025, 08:47:38 PM »
 Pair of restored two piece rotors, separated, cleaned, soaked in evaporust, reassembled, new races and machined.  Rotors come with new races, bearings and seals..  $500 for the pair plus shipping..
Re: 68 - 70 two piece rotor set
« Reply #1 on: March 06, 2025, 09:17:52 PM »
Is rotor surface or "hat" new or is this a used rotor surface that has been cleaned?
Offline kgranhold
« Reply #2 on: March 06, 2025, 09:33:52 PM »
The rotor hat was separated from the hub, cleaned, reassembled and then the rotor surface machined, or resurfaced.  The rotor thickness, after machining, is indicated on the rotor face in the picture.
« Reply #3 on: March 06, 2025, 10:39:59 PM »
.875 is minimum thickness and .046 is left to use up on the thickest rotor of the two so they are both still within minimum spec. They look very nicely done.  I am looking for a set that will turn at least one more time if need be.  Best of luck with your sale.
