Author Topic: Driveshaft install  (Read 5807 times)
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
Re: Driveshaft install
« Reply #15 on: June 15, 2011, 06:11:26 AM »
Building 2 million+???  I'll bet they had a special fixture that did it!
66 Metuch Conv
Nightmist, Std Blu Int
« Reply #16 on: June 15, 2011, 11:40:00 AM »
The only squeezing required is before seating the cups into the pinion, which can usually be done by hand.  Once the u-joint cups are seated in the pinion, they don't need to be held when tightening the u-bolts... other than just making sure everything stays straight.
Offline 68 S Code
« Reply #17 on: June 16, 2011, 12:17:05 AM »
Got it. Thanks to everyone who helped to clear this up for a newbie.
Offline 68 S Code
« Reply #18 on: June 21, 2011, 09:34:42 AM »
I finished the install of the driveshaft and I saw that the small tabs in the yoke keep the cups seated. Once you get the cups past the tab you can toque the nuts on the u-bolt. Tried using the clamp but it just got in the way.
