Author Topic: How are the molded rubber connectors made?  (Read 2856 times)
Offline bluestang65
« on: June 12, 2011, 12:34:37 PM »
If a guy wants to make them, how would that be done?  I know most everything is available as a reproduction, but I'm doing something outside the norm.  I've seen every type of terminal available from places like NAPA or a few online vendors, but I don't see anything on the standard old rubber molded Ford plugs.  Seems to be identical to the main disconnect on the 4 flat trailer plugs.  Anyone know how they're made?
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
Re: How are the molded rubber connectors made?
« Reply #1 on: June 12, 2011, 01:48:35 PM »
1) Tool & Die Maker hand-carves a 2 piece female mold
2) Resin or rubber is decided on with the desired characteristics
3) Resin in liquid state is injected under pressure, into the mold
4) After curing, the plug, with wires/pins encased in hardened resin, is removed from mold.
66 Metuch Conv
Nightmist, Std Blu Int
Offline bluestang65
« Reply #2 on: June 12, 2011, 02:24:30 PM »
Where would one get the terminals themselves?
« Reply #3 on: June 12, 2011, 09:57:53 PM »
A jig is needed to keep the wires and pins centered and/or aligned within the mold itself.  I've inquired about the machines that do this, and they are fairly large...typically blasting cabinet sized.  Used machines run about $10k.
Given the price and the fact that striped colored wires are specialty orders (think $500 minimum purchase), I decided to continue harvesting used harnesses for plugs.  Several vendors sell a variety of 1 to 8 pin molded connectors; I like http://www.delcity.com or waytek wiring.
Offline bryancobb
  • 2009 Ridn' Around
« Reply #4 on: June 12, 2011, 10:42:15 PM »
Probably mouser.com or similar.
66 Metuch Conv
