Author Topic: 1969 Boss 302 Manual Steering Center Link, Idler Arm, Tie Rod assys. $200+ship  (Read 403 times)
Offline fastmerc
Greetings!
From an original 1969 Boss2 which was being perverted....   Car was allegedly pulled from the high desert out here after decades, and then sent to the shop for lots of far from stock work.  Original components best I can tell, and patina says desert......for a long time.
Center link- manual steering,  Idler Arm C7ZZ-3355-B, and what appear to be original tie rod assys.  Some of the tie rod ends appear to be in great shape but for the condition of the replaceable rubber boots.   (I do not have the pitman arm.)
All fasteners appear to be original.   The adjuster sleeves appear to have never had a water pump pliers on them.....or the nuts/bolts a funky socket.
New bushing in picture is from a '66 Galaxie with P/S, and may not be correct here. Just used it as a prop after I found out there were some differences along the way.
Soaked some of the nuts in PB Blaster for several days before I was finally able to get them loose by hand.  I wanted see what the area on the center link looked like where it contacts the bushing.   Looks great!
Shipping from 95043, CA.
Thanks for looking!
Boss302 is quieter when you sit in front of it!
