Author Topic: Voltage Reg  (Read 3597 times)
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
Voltage Reg
« on: June 10, 2011, 10:12:19 AM »
For my MAR 66 Metuchen C-Code...What are folks doing for a voltage regulator for Concours Driven?
66 Metuch Conv
Nightmist, Std Blu Int
Re: Voltage Reg
« Reply #1 on: June 10, 2011, 10:17:55 AM »
Get an AMK repro to swap out at the shows, but when driving the car, use an electronic Motocraft unit.
Offline bryancobb
  • 2009 Ridn' Around
Re: Voltage Reg
« Reply #2 on: June 10, 2011, 10:41:09 AM »
Thanks.
I have a Dead Nuts On, alternator.  I think their new "insides" puts out 60Amps???
On AMK's list, they have AUTOLITEs and FoMoCo 's for 38 & 42 amps, and 45 & 55 amps.
It looks like the C5TF-AUTOLITE would be best since it's for 55 amps?  Right?
« Last Edit: June 10, 2011, 10:50:44 AM by bryancobb »
66 Metuch Conv
Re: Voltage Reg
« Reply #3 on: June 10, 2011, 11:03:49 AM »
Believe the most typical for a power top/ac car would be the yellow print one.  Although, some original cars have been contradictory in that matter.
Offline Brant
Re: Voltage Reg
« Reply #4 on: June 10, 2011, 11:08:17 AM »
Thanks.
All of the AMK Voltage Regulators are the same internally, so you just go with the stamping you want or need.
Offline bryancobb
  • 2009 Ridn' Around
Re: Voltage Reg
« Reply #5 on: June 10, 2011, 11:35:10 AM »
Thanks guys.
66 Metuch Conv
Offline bryancobb
  • 2009 Ridn' Around
Re: Voltage Reg
« Reply #6 on: June 10, 2011, 11:41:59 AM »
Brant,
Is your EG424 an AMK repro?  Your pic shows screws.  I thought it should have rivets?
66 Metuch Conv
Offline Brant
Re: Voltage Reg
« Reply #7 on: June 10, 2011, 12:40:59 PM »
Brant,
Yes, it is an AMK repro.  The earlier Voltage Regulators had screws holding the cover on.  Later, rivets were used.  Note:  That EG-424 is on backorder from AMK right now  :(
Offline ChrisV289
Re: Voltage Reg
« Reply #8 on: June 10, 2011, 12:45:34 PM »
Thanks.
How are the Dead Nuts on alternators?  I've been thinking about purchasing one?  Anyone have any problems with them?  OR what is everyone else using?
2009 V6 Mustang Coupe
Offline bryancobb
  • 2009 Ridn' Around
Re: Voltage Reg
« Reply #9 on: June 10, 2011, 01:08:26 PM »
The alternator?  Well... It's Dead Nuts On...I guess.  The guy is super knowledgeable, has OE cores, not repops, (I thinks he's getting set up to make clone housings)  he has brand new stators manufactured for him, (not rewound ones), he stamps the right color and dates FOR YOUR CAR.  He's gonna start DIPPING the pulleys and fans instead of yellow zinc.
I still haven't sat the engine back in so the jury is still out on how it actually works.
66 Metuch Conv
Re: Voltage Reg
« Reply #10 on: June 10, 2011, 08:38:42 PM »
............. He's gonna start DIPPING the pulleys and fans instead of yellow zinc......
Dipping ???  Don't understand the comment since zinc dichromate is a dipping process
Offline bryancobb
  • 2009 Ridn' Around
Re: Voltage Reg
« Reply #11 on: June 11, 2011, 04:45:17 PM »
I need to clarify.  He said on 66 289's like my car, the pulley and fan are black and Ford dipped then in a pretty thin black paint that barely had enough pigment in it to color them black.
My pulley and fan is yellow zinc dichromate, which, according to what I saw in Mannel's book, is incorrect.
66 Metuch Conv
Re: Voltage Reg
« Reply #12 on: June 12, 2011, 12:43:22 AM »
     The transition from the black painted to the zinc dichromate happened in later 66 production so some cars did have the zinc gold plated fans and some did not depending on when they were produced at what time in which plant. I know San Jose was sometime in mid production based on the GT350's I have seen. Bob
« Last Edit: June 12, 2011, 12:46:43 AM by Bob Gaines »
Offline bryancobb
  • 2009 Ridn' Around
Re: Voltage Reg
« Reply #13 on: June 12, 2011, 08:36:18 AM »
I don't think my car would be a "later" 66 car.  So, I guess the black is right for mine.
66 Metuch Conv
