Author Topic: Spot weld classification standard  (Read 2272 times)
Offline RickP330
« on: January 14, 2025, 10:08:24 AM »
Hi guys,
I have hit a dead end on this one.  I am working with the 1967 Weld/sealant manual.  It is calling out Class 1,2 and 3 spot welds.  Class 3 seem to be the most common and structural style welds (Frame rails, torque boxes, rocker panels etc).  Class 1 and 2 seem to be on door skins and hood skins.
I want to duplicate factory style "structural" Class 3 spot welds.  A typical destructive test is a peel test and a measurement of the weld nugget diameter.  However, I can find no reference to the weld classifications anywhere.  I did find later model specifications, but clearly things have changed, and they classify Class 1 spot welds as structural now.
Does anyone have a reference to the spot weld classifications in '67 that might hint at the peel test weld nugget diameters?
Optionally I am trying to get my hands on some old spot welds to destructively test and measure - but I am hoping to do both.
Much Thanks
Rick
Re: Spot weld classification standard
« Reply #1 on: January 14, 2025, 12:34:19 PM »
I'm no expert in this space, but would think that instead of hunting down manufacturer Class designations for spot welds that there should be specifications for spot welding based on the thickness and metal type being welded.
This looks like a decent reference, I'm sure there are many more, maybe library books too.  Ford may have published documentation on this too, like the sheet metal stamping one.
https://www.pwrwp.co.uk/spot-welding-technical/
Sections like frame rails, while thicker, would also be galvanized, so possibly a minor factor when determining current/cycle time.
Offline RickP330
« Reply #2 on: January 15, 2025, 06:41:55 PM »
Thanks Charles,
Someone from another forum helped me out.  He found the attached document - while dated 2002 it seems reasonable to use it as a guide here.  Apparently the Class 1,2 &3 spot weld refer to the "finish" not the strength of the weld.  Class 1 and 2 are used near body panels where cosmetics are of concern.  There is a table for weld nugget diameter and that seems to agree with some industry standards I found so I think I am okay.  Thank you.
Rick
« Reply #3 on: January 15, 2025, 07:09:03 PM »
Nice!
« Reply #4 on: January 15, 2025, 08:37:43 PM »
Keep in mind that assembly line spot welds were done by a rather large "pincer" type device that was calibrated.
Offline RickP330
« Reply #5 on: January 17, 2025, 06:54:11 PM »
Hi Jim,
Honestly I am concerned about that.  Besides factory welding units were probably much higher current than I have available at home.  I have gotten good welding results with the following welder though.  I'm pretty confident it will work well.
RP
Offline RickP330
« Reply #6 on: January 17, 2025, 07:00:37 PM »
I made multiple weld coupons.  I am settling on a general weld for now I consider acceptable.  16 ga sheet metal using an all copper weld through primer.  It fits class 3 weld finish and has a minimum of .23" weld nugget.  According to the specifications it needs to be larger than .17".
RP
« Reply #7 on: January 17, 2025, 09:30:29 PM »
Part of the challenge I've witnessed through the years is that some of the spot weld areas are just not accessable with the car assembled so those corners, pockets or covered areas are very difficult or impossible to replicate.
Do have a number of Ford Factory welding manuals showing a ton of details about the systems, tools, how to maintain and all that I need to find time to look through to see if it references any of the details you have asked about
Offline RickP330
« Reply #8 on: January 20, 2025, 12:04:29 PM »
Hi Jeff,
That's awesome.  I have the Jim Osborn books.  What other references do you have?  Is it something I might be able to find for myself, or are they one off references?
I do realize that I will not be able to replicate all the welds to 100% fidelity - but I will do the best I can.
I also know there are multiple factory brazes here and there and some MIG style welds.  Such as the shock towers for BB cars.  However, none of those welds are documented in the Osborn books.  I'd like to know more about those too.
RP
PS for those welds I cannot reach I was planning on punching a hole in the top side and TIG welding a nugget there.
« Reply #9 on: January 20, 2025, 05:38:09 PM »
Wished I could have found time to photo and share a few pages from the manual earlier but here goes.  Picked a few that touched on topics brought up in this thread as well as a few others related to the hand welding fixtures, thinking that might be of  interest to others that may find and read the thread. Believe it would be difficult to find another copy, not something of high interest to many people, no pretty flashy color pictures of cars and such, but who knows. Just knowing that they were published and having a title should help a lot in doing in conducting search for a copy
Hope these help you and others reading the thread
« Last Edit: January 20, 2025, 05:40:44 PM by J_Speegle »
Offline RickP330
« Reply #10 on: April 06, 2025, 07:32:05 PM »
Jeff,
That is fantastic, thank you!
It might be a big ask, but if you are willing to trust me with it - I will scan it in and share a copy so we can put it in the library.  I can send you a flat rate box to send it to me in and return.  I did a quick search on line, and only later versions of that book come up.
Regardless, I will study what you posted and absorb.  Thank you!
Rick
Offline RickP330
« Reply #11 on: April 06, 2025, 07:38:56 PM »
Well that certainly settles the question of what the weld classifications are!  Thank you Jeff!
Offline RickP330
« Reply #12 on: April 06, 2025, 07:50:11 PM »
Making slow and steady progress on this project.
I had the parts made for the first phase of my welding cart.  Did some basic welding on it (yes some spot welds).  I have some primer and black enamel to go on next.
Someone here also answered my classified ad looking for '67 spot welds from a donor so I can qualitatively pull test them and compare them to welds I can make with the Miller.
I'll keep you posted with results.  Thanks for following.
Rick
