Well that isn't what they wanted to do or did last time I paid a professional shop to do the job. And they agreed that their normal temps were too high for the springs so they had a work around. Just my experience
Not mine. I was taught the process by two MCA Gold Card Judges over30 years ago. You might know them, Rich and Bruce (who unfortunately has passed away). It's a process that can be easily done at home.
Some pictures of what I did at home.
Here a link that describes it:
https://en.wikipedia.org/wiki/Phosphate_conversion_coating - Some of the text is below.
Phosphate conversion coating is a chemical treatment applied to steel parts that creates a thin adhering layer of iron, zinc, or manganese phosphates to improve corrosion resistance or lubrication or as a foundation for subsequent coatings or painting. It is one of the most common types of conversion coating. The process is also called phosphate coating, phosphatization, phosphatizing, or phosphating. It is also known by the trade name Parkerizing, especially when applied to firearms and other military equipment.
A phosphate coating is usually obtained by applying to the steel part a dilute solution of phosphoric acid, possibly with soluble iron, zinc, and/or manganese salts. The solution may be applied by sponging, spraying, or immersion. Phosphate conversion coatings can also be used on aluminium, zinc, cadmium, silver and tin.
