Author Topic: Water Pump Pulley - 1969 428 Cobra Jet  (Read 131 times)
Offline 69gtconv
« on: November 14, 2024, 06:44:11 PM »
From the Pulley Spreadsheet in the Library Section, two (2) water pump pulleys were used for 1969 Cobra Jet cars with smog & no AC. The distinguishing factor between the two pulleys in the spreadsheet is the car's rear-end axle ratio.
The Mustang 428 CJ Registry Website lists the same two water pump pulleys, but their distinguishing factor between the two pulleys is the car's build date.
Which is the correct distinguishing factor?
I'll be using one of these in my March 17, 1969 built Q-Code Convertible, which has smog and power steering, no a/c, 3.5:1 axle ratio.
Thanks in advance.
« Last Edit: November 14, 2024, 06:46:42 PM by 69gtconv »
1966 T-Code Coupe (1st Car, Sold)
1967 GT 350 4-Speed w/original Paxton SC (Sold)
1970 Boss 302, 4-Speed (Sold)
1969 GT S-Code Convertible, Automatic (sold)
1969 Cougar XR7 R-Code Convertible, 4-Speed (sold)
1969 Mach 1 R- Code, 4-Speed (being restored)
1969 GT Q-Code Convertible (to be restored)
Offline sah62
Re: Water Pump Pulley - 1969 428 Cobra Jet
« Reply #1 on: November 15, 2024, 04:47:04 PM »
Repeating what I added to this same topic on the 428 CJ forum:
Quote
We may need to revise the ID page with respect to that build date information. I see the 2/17/69 date listed for the 1969 390 GT, but not the 428 CJ.
Looking at build sheets, we see three different water pump pulleys listed for 1969 CJ Mustangs:
6AEA
8AEC
8OEA
Every SCJ seems to use the 8AEC pulley. Most of the CJs use the 8OEA pulley.  I have a small number of CJs using the 8AEC pulley, all but one has an "S" axle code (3.50 traction-lok, one is "A" 3.50 open), and they do happen to be later builds. All of the cars with a 6AEA pulley are CJs, and all have a/c.
Scott Hollenbeck
2019 Lincoln MKZ 3.0T AWD
2003 Mercury Marauder 300A
(more non-Ford stuff)
Offline 69gtconv
« Reply #2 on: November 15, 2024, 05:20:50 PM »
