Author Topic: Water Pump Pulley - 1969 428 Cobra Jet  (Read 49 times)
Offline 69gtconv
« on: November 14, 2024, 06:44:11 PM »
From the Pulley Spreadsheet in the Library Section, two (2) water pump pulleys were used for 1969 Cobra Jet cars with smog & no AC. The distinguishing factor between the two pulleys in the spreadsheet is the car's rear-end axle ratio.
The Mustang 428 CJ Registry Website lists the same two water pump pulleys, but their distinguishing factor between the two pulleys is the car's build date.
Which is the correct distinguishing factor?
I'll be using one of these in my March 17, 1969 built Q-Code Convertible, which has smog and power steering, no a/c, 3.5:1 axle ratio.
Thanks in advance.
« Last Edit: November 14, 2024, 06:46:42 PM by 69gtconv »
1966 T-Code Coupe (1st Car, Sold)
1967 GT 350 4-Speed w/original Paxton SC (Sold)
1970 Boss 302, 4-Speed (Sold)
1969 GT S-Code Convertible, Automatic (sold)
1969 Cougar XR7 R-Code Convertible, 4-Speed (sold)
1969 Mach 1 R- Code, 4-Speed (being restored)
1969 GT Q-Code Convertible (to be restored)
