Author Topic: Blue Paint on Transmission Mount  (Read 180 times)
Offline schusa
« on: November 14, 2024, 01:04:29 PM »
I am restoring a 70 Boss 302, build date 6/29/1970 at the Dearborn assembly plant.  In cleaning up the transmission mount I have found what looks like Ford Corporate blue engine paint on the mount (See Pictures Attached).  The paint is on the rubber and bare metal portions of the mount and is on the portion of the mount that would have been mated up to the transmission when installed indicating that it was likely put on before the mount was installed.  All research that I have seen indicate that the non-rubberized portions of the mount are not painted.  In addition I am essentially the second owner of the car and the original owner said that the car had not been apart before.  Has anyone seen this before?  Did some mounts get painted?  Is this possibly an assembly line color marking to assist the assembly process?  Is it something I should try to reproduce while restoring?  Any thoughts or opinions would be greatly appreciated.
Re: Blue Paint on Transmission Mount
« Reply #1 on: November 14, 2024, 02:27:37 PM »
Looking through my collect I don't find another 70 manual transmission mount. Guess you have already looked for the engineering number on the mount and confirmed it might be original to the car. Just a good thing to start with.
Lacking other examples or confirmation it will be up to you to determine if you have enough to reproduce the marking at this point. Good think is its not very hard to replace it if you add it later
Offline Anghelrestorations
    • Anghel Restorations
« Reply #2 on: November 14, 2024, 04:54:24 PM »
The blue on the small block transmission mounts is not unusual.  This photo here shows an original one from an October 1969 built Boss 302 I have on my bench.  The whole entire mount would not be covered in blue, but typically it would be like you see in the photo...
20241114_134101 by Marcus Anghel, on Flickr
Marcus Anghel
www.anghelrestorations.com
« Reply #3 on: November 14, 2024, 04:57:37 PM »
Thanks Marcus - Had not seen that. The dozen or so I have from 70 examples are forest green or red.
Do have a service replacement with green also
Offline 69gtconv
« Reply #4 on: November 14, 2024, 08:29:03 PM »
I've got red on my '69 Dearborn RUG-AE2
1966 T-Code Coupe (1st Car, Sold)
1967 GT 350 4-Speed w/original Paxton SC (Sold)
1970 Boss 302, 4-Speed (Sold)
1969 GT S-Code Convertible, Automatic (sold)
1969 Cougar XR7 R-Code Convertible, 4-Speed (sold)
1969 Mach 1 R- Code, 4-Speed (being restored)
1969 GT Q-Code Convertible (to be restored)
« Reply #5 on: November 14, 2024, 09:39:22 PM »
The transmission mount on a big block transmission and a smallblock transmission mount are typically different shaped so it is no surprise that they would be marked differently too. Red is a typical color I see marked on the big block trans mount.
Offline schusa
« Reply #6 on: November 14, 2024, 11:50:51 PM »
Thank you everyone for putting some light on this subject.
Marcus can you tell if the paint was sprayed or brushed on.  As thick as it is and with some of the runs I see on mine I am guessing that it was brushed on.
« Reply #7 on: Today at 01:23:26 AM »
It was definitely brushed on.....
Marcus Anghel
« Reply #8 on: Today at 02:39:45 AM »
+1 On every one I've ever seen in person or pictures
