Author Topic: FE camshaft identification  (Read 1497 times)
Offline Ashley
« on: November 02, 2024, 09:45:58 PM »
Hello: Anyone have any info on identifying C6OZ-6250-B camshaft. I have a cam with blue paint daub by rear journal. Cam was in my S code 67 coupe. Any info would be greatly appreciated.  Thanks
« Last Edit: November 03, 2024, 02:07:14 AM by J_Speegle »
Offline Keith Stem
Re: FE camshaft identification
« Reply #1 on: November 03, 2024, 07:07:53 AM »
If you will look on the 428 CJ website under Engine Information, Component Information, then select Camshafts you will see the cam C6OZ 6250-B description. The text and picture refer to a blue paint swab. If you need the cam specifications here are the timing specifications.
Int Open 18 BTDC   Int Close 72 ABDC   Intake Lift 0.487    Intake Duration    270   Int CL 117 ATDC   Ex Open 82 BBDC   Ex Close 28 ATDC   Exhaust Lift 0.495
Exhaust Duration 290     Ex CL 114 BTDC      OverLap 46       Overlap CL 5 ATDC   Lobe Separation 117   Notes Stock CL / GT CAM
« Last Edit: November 03, 2024, 11:07:47 AM by Keith Stem »
