Author Topic: 68 GT grille color  (Read 7559 times)
Offline 68 S Code
68 GT grille color
« on: June 04, 2011, 11:07:33 PM »
NOTE: The following 21 replies are from various individual threads that have been merged on Jan 19 2022
This is the last big piece to repainted. Did the SG paint a long time ago and heard it needs to be two tone. Need some direction as to the paint mix for the blue/grey color. Is it more blue or more grey? Is it a metallic or solid. Getting ready for final trim assembly. Regarding assembly do I want to have grille and all trim in that area done and bumper goes on last?
« Last Edit: January 19, 2022, 05:16:33 PM by J_Speegle »
Offline mach1one
Re: 68 GT grille color
« Reply #1 on: June 11, 2011, 01:25:27 PM »
I believe its a dark blue metallic
Offline 68 S Code
« Reply #2 on: June 11, 2011, 11:29:29 PM »
So it would be like 68 Presidential Blue?
« Reply #3 on: June 12, 2011, 01:20:29 AM »
The grill out side of the large corral is black and the area inside of the small corral is black. The inside of the large corral is grey metallic.  Just remembered there was a thread here a while back with a pictures. I have the grey color custom mixed. The steel braces are semi gloss black and the rivets that held them were natural and are available from AMK. Marty
Offline 68 S Code
« Reply #4 on: June 13, 2011, 10:08:10 AM »
Marty I will try to attach a pic of an NOS grille which was up on eBay a few months ago. It seems to correspond with what you describe. If you have a mix number than i will try to see if I can get it mixed around here. Thanks for the information.
« Reply #5 on: June 14, 2011, 12:13:16 AM »
What I used was
Sherwin Williams
ACRYLYD
JS7130SG Blue - Gray
I had it matched off a original 67 grille. Marty
Offline 68 S Code
« Reply #6 on: June 14, 2011, 12:18:31 AM »
Marty so the center of a 68 Gt grille is the 67 grille color? Thanks for the info and the SW color code. Is it metallic in nature?
« Reply #7 on: June 14, 2011, 09:03:36 AM »
Yes it is the 67 gray metallic color. Do not forget the the center of the small corral is black. Marty
Offline 68 S Code
« Reply #8 on: June 14, 2011, 09:51:37 AM »
Marty I have the center noted. The brackets behind need to stay black with no overspray as they would have been installed after painting? Touch up rivet heads with silver. Backside off center coral is just overspray and not thoroughly painted? Is this correct? Thanks.
« Reply #9 on: June 14, 2011, 08:14:53 PM »
You are correct. Marty
Offline 68 S Code
« Reply #10 on: June 14, 2011, 09:31:43 PM »
Thanks Marty.
68 NOS GT grill
« Reply #11 on: April 22, 2018, 09:30:38 AM »
I found this 68 NOS GT grill for my current project and thought I would share some pictures with you. I have never seen a NOS GT grill and thought it was cool to see the different colors and poor quality of paint work on the back. I was lucky to find NOS parts for every part of this grill assembly.
« Last Edit: January 19, 2022, 05:16:06 PM by J_Speegle »
Offline TLea
68 GT grille finish
« Reply #12 on: May 06, 2021, 12:58:55 PM »
What is the correct finish for 68 GT grille? I assume brackets are black and rivets natural? Dearborn CJ if it matters
Re: 68 GT grille finish
« Reply #13 on: May 06, 2021, 08:51:22 PM »
Tim brackets are sg black, tubular rivets can be black natural or brown. The grill mesh is black out side the large coral and dark argent inside of it and it is black inside the small corral.
Here is a picture of a NOS grill I used on our 68 S code.
Offline TLea
« Reply #14 on: May 07, 2021, 08:41:58 AM »
Thanks Marty. Interesting for sure. Was there hard tape line behind chrome?
