Author Topic: WTB 68 non finned front brake drums  (Read 3182 times)
Offline dkknab
« on: October 20, 2024, 08:41:32 PM »
I have the hubs coming from another source but would happily take front hub and drum x 2 for my 68 coupe
« Last Edit: October 20, 2024, 08:48:48 PM by dkknab »
David Knab
289 2V, AT, PS
Nugget Gold Interior
Re: WTB 68 non finned front brake drums
« Reply #1 on: October 20, 2024, 11:11:48 PM »
You had better confirm what the maximum wear size the inside diameter can be so that you know what is usable and what is junk. There is no use buying a out of spec drum for your occasional driver car. I don't mess with front drum cars so don't ask me.  For example a rear 10 inch drum maximum spec is 10.060 before it becomes dangerous.
Offline dkknab
« Reply #2 on: October 21, 2024, 08:50:22 AM »
Thanks Bob I'll definitely keep that in mind. I was reading in my 66 Ford mustang et al Shop Manual that if the drum diameter is 10.03 or 10.06 then a lining could be installed.  Is that something a local shop can do or does it need to be sent out to someone?
I'd really rather go with new front drums non finned but I've not been able to find any sources.  Rear drums you can find and 4 bolt fronts too but I've not been able to locate 5 bolt fronts that are staked to front hubs.
« Last Edit: October 21, 2024, 09:31:46 AM by dkknab »
David Knab
289 2V, AT, PS
« Reply #3 on: October 21, 2024, 11:12:50 AM »
I currently have some rear drums from a GT350 out to be relined by the one and only shop I have found through extensive internet search that does that. They are 300.00 plus shipping each to reline your core if no other repair work is needed.
Offline KevinK
« Reply #4 on: October 21, 2024, 01:36:53 PM »
I have some drums which are pretty clean.  Are there any markings you are looking for?
MCA #33800, Gold Card 3rd Gen
BAMA Member
Offline dkknab
« Reply #5 on: October 21, 2024, 03:01:58 PM »
I show my car in concours driven so no markings or date codes necessary though if you had something just before my build date of 5 April  68 would be fantastic. And as Bob mentioned earlier,  they do need to be within specs.
David Knab
289 2V, AT, PS
« Reply #6 on: October 23, 2024, 01:52:30 PM »
Do the front drums have a groove cut around the outside or are they flat?
Offline dkknab
« Reply #7 on: October 23, 2024, 02:34:19 PM »
I'm not sure I understand the question.  Here's my driver side drum from underneath the car that might help.
David Knab
289 2V, AT, PS
Offline KevinK
« Reply #8 on: October 23, 2024, 02:41:28 PM »
The picture shows finned drums.  I thought You were looking for drums without fins?
« Last Edit: October 23, 2024, 02:44:34 PM by KevinK »
BAMA Member
Offline dkknab
« Reply #9 on: October 23, 2024, 02:54:22 PM »
I am looking for drums with no fins.  I was just responding to Bossbill question and showed the drum I currently have which is incorrect.  Hope that makes sense.
David Knab
289 2V, AT, PS
Offline dkknab
« Reply #10 on: October 23, 2024, 02:56:27 PM »
I guess another question is when did Ford stop using front non finned drums ? When did they start using finned drums?
David Knab
289 2V, AT, PS
« Reply #11 on: October 23, 2024, 05:29:58 PM »
SNIP
SNIP
It looks like replacements are smooth or with a groove or two around the outside and the originals are finned?
Visa-Versa maybe?
My parts car has the smooth drums (of unknown quality).
[my view of this thread was old and I didn't see Kevin's post]
« Last Edit: October 23, 2024, 05:48:20 PM by Bossbill »
Offline dkknab
« Reply #12 on: October 23, 2024, 06:10:39 PM »
Visa-Versa maybe?
According to MCA and other info the originals don't have fins.  So the $64,000 question is where do you get non finned replacements. Any suggestions?
David Knab
289 2V, AT, PS
« Reply #13 on: October 23, 2024, 06:49:04 PM »
The comment about the groove has to do with a groove cut around the outside diameter of the sides of the drum on a drum that does not have fins. Some non finned drums have the groove and others do not . I believe it is a mfg issue.  It is not however a issue that dkknab needs to worry about in his quest for usable non finned front brake drums. Both sides need to match (groove or no groove) otherwise if noticed it may be a deduction or at least note in concours . That situation would probably even not be noticed . On the other hand a finned drum vs. a non finned drum is EXTREMELY noticeable .
« Reply #14 on: October 23, 2024, 06:58:58 PM »
PM sent to dkkanb.
