Author Topic: Mach One trim piece color question  (Read 1133 times)
Offline DaveF
« on: October 09, 2024, 11:35:16 PM »
My question is about the proper color of the Chevron shaped piece that is attached to the fill panel behind the front bumper. It is attached with 4 small screws. When I took it off of the vehicle, it was painted black, but I?m not sure that is correct. Should it be the same charcoal color as the grill and rocker moldings, or just black? Thanks
1970 Mustang Mach One
428 SCJ w/Drag Pak 3.91
Metuchen plant
Built 9/5/1969
Offline DougDyar
Re: Mach One trim piece color question
« Reply #1 on: October 11, 2024, 09:55:21 AM »
Only a portion is painted.
Yes, same color as the paint on the headlight doors and the trim around them.
I don't own a Mach 1, but I believe that the rocker trim is a darker gray...
0F02G203277
Offline DaveF
« Reply #2 on: October 13, 2024, 07:46:24 AM »
When you say that you think that only a portion is painted, what do you mean?
Metuchen plant
Built 9/5/1969
Offline DougDyar
« Reply #3 on: October 13, 2024, 09:56:01 AM »
Can't find a better pic, so I posted this one.
The painted portion is the flat, center part. The raised edges are left unpainted.
0F02G203277
Offline DaveF
« Reply #4 on: October 14, 2024, 11:05:30 AM »
So, am I correct in understanding that the headlight doors, grill and fill panel are all the same shade of grey?
Metuchen plant
Built 9/5/1969
Offline DaveF
« Reply #5 on: October 14, 2024, 11:49:46 AM »
Here is a better photo.
Metuchen plant
Built 9/5/1969
Offline DougDyar
« Reply #6 on: October 15, 2024, 08:10:56 AM »
Yes
0F02G203277
