Author Topic: Braking problem - 68 GT350  (Read 5062 times)
Re: Braking problem - 68 GT350
« Reply #15 on: December 01, 2024, 09:49:47 PM »
Do you have the calipers on the correct sides?
« Reply #16 on: December 01, 2024, 11:58:20 PM »
+1 . They are right and left specific.
Offline 69GT350H
« Reply #17 on: December 25, 2024, 11:10:20 AM »
I did not see this in person, so forgive me if I have any of the details wrong. As it was explained to me, in the power booster there is a plastic cup that the adjustable rod sets into. I was told the cup was cracked. When assembled with the adjustable rod and MC installed, when the brakes are depressed, the cup would split open and the rod would slip into the crack and not travel the proper and required distance. So this is why when we did all our measurements the rod length was proper, but when actually put to use, the rod was short. A replacement booster was installed and the car's brakes/stops correctly now.
Offline 69GT350H
« Reply #18 on: December 27, 2024, 05:47:30 PM »
Strange, I just got this email notification, but I do not see it here...
A reply has been posted to a topic you are watching by lightwtjet.
 View the reply at: https://www.concoursmustang.com/forum/index.php?topic=30205.new;topicseen#new
 Unsubscribe to this topic by using this link: https://www.concoursmustang.com/forum/index.php?action=notify;topic=30205.0
 The text of the reply is shown below:
 Many of us have had to replace the wheel cylinders. Yours may be wrong. Can someone tell him the diameter of the piston in the correct rear wheel cylinder?
 Regards,
 The ConcoursMustang Forums Team.
« Last Edit: December 28, 2024, 10:51:37 PM by J_Speegle »
« Reply #19 on: December 28, 2024, 10:51:20 PM »
 Regards,
This can be the result of someone posting a response then deleting it. Sometimes you will find members on sites doing this so that they can follow the discussion but don't have anything to add at the moment. Can't say that is what took place but a possibility
