Author Topic: Front of car question for a 66  (Read 1038 times)
Offline litew8t
« on: June 02, 2011, 01:01:49 PM »
Hi
Here is weird question I had gotten.
I'm in the process of getting my 66 coupe painted,One of the guys at the shop said when you look staight on to the front on the car, the black part that shows from front of rad does not look even.
I think its because the 1 headlight assembly is a little wider than the other ( because of where battery sits)
They want to know if they should black out that part of the headlight assembly to make it look even.
I do not think so
Thoughts??
Re: Front of car question
« Reply #1 on: June 02, 2011, 03:21:33 PM »
the entire radiator support is semi-gloss black. parts bolted to that are body color. no black-out on bolted on parts. the only exception is the small tab under the center of the grille that has one screw thru it.
