Author Topic: 1969 351W water pump markings  (Read 3212 times)
Offline 69zombie
« on: September 15, 2024, 12:40:23 AM »
Have a 01/16/69 build GT350 convertible. What would be typical markings on the water pump if it were original?
« Last Edit: September 15, 2024, 05:01:31 PM by J_Speegle »
Re: 1969 351W water pump markings
« Reply #1 on: September 15, 2024, 01:14:13 AM »
It would typically be a C8OE-D casting . Possibly a J. It would be painted Ford dark blue given it was bolted on when the engine was painted . It would have about a inch of the inlet bare cast iron from being masked off during the engine painting process. The hub flange was masked off so as to be unpainted also. Don't forget to paint the bypass hose and clamps blue also as they were on the engine when it was painted.
« Last Edit: September 15, 2024, 05:01:39 PM by J_Speegle »
Offline 69zombie
« Reply #2 on: September 15, 2024, 06:52:05 AM »
Thanks for passing on your knowledge Bob. Add me to the the long list of people your kind enough to help.
Tom
« Last Edit: September 15, 2024, 05:01:47 PM by J_Speegle »
Offline 69zombie
« Reply #3 on: October 23, 2024, 11:36:12 PM »
Finally got around to checking.To my old eyes it appears to be marked C80E-A.Not claiming it's original, the engine has previously been rebuilt at least once to my knowledge.
Tom
« Reply #4 on: October 24, 2024, 12:47:09 AM »
Tom
Most likely replaced if a C8OE-A. In 1969 production the C8OE-D would have been most typical based on a 1/16/69 build date.
« Reply #5 on: October 24, 2024, 01:04:54 PM »
Was under the impression that the 1966-69 small block water pumps had casting numbers: C6OE-A, C8OE-D, C8AE-A, and C8AE-J. There are more?
« Last Edit: October 24, 2024, 01:07:04 PM by krelboyne »
« Reply #6 on: October 24, 2024, 07:32:06 PM »
The C8OE-A is what the core sitting on my shelf reads.
