Author Topic: Fuel gauge reading full  (Read 966 times)
Offline 68 GT
« on: September 12, 2024, 08:15:53 PM »
My fuel gauge on my 68 coupe started to read full all of the time. It used to work until a few weeks ago. I had purchased a new sending unit awhile back, with the tank empty, I dumped in a give amount of gas and verified the gauge was reading correctly for the amount of gas I dumped in. I had to drain the tank a couple of times, give the float lever a small tweak and check the indications again by dumping in a known amount of gas. After a few attempts, the gauge was reading pretty close to how many gallons were in the tank. But now, the gauge always shows full, or close to it. With the key off, the gauge will go to empty, turn the key on, gauge goes to full, or nearly full. Any advice on why it?s always reading full, nearly full all of the time?
« Last Edit: September 19, 2024, 05:16:16 PM by Bob Gaines »
VIN 7T01C246XXX
Actual build date 5-11-67
VIN 8F01J208XXX
Actual build date 6-27-68
Offline 67350#1242
Re: Full gauge reading full
« Reply #1 on: September 12, 2024, 08:42:44 PM »
Check for a short in the wire to the sender, or pull the connection to sender off and see if the gauge drops.
If the gauge drops, the problem is in the sender.    If there is a short in the wiring, the gauge will stay high.
67 Coupe SJ 11/16/66
67 GT350 SJ 2/01/67
Offline 68 GT
« Reply #2 on: September 14, 2024, 06:38:09 PM »
With the ignition on, gas gauge read full, disconnected the sending unit, the gauge went to empty. Looks like I don?t have to locate a short, will be replacing the sending unit. Thanks for the tip!!
VIN 7T01C246XXX
VIN 8F01J208XXX
