Author Topic: Early 1965 Mustang HiPo 289 Special K code C4OF-AL  (Read 2708 times)
Offline SFM6S1640
« on: June 02, 2011, 02:45:38 AM »
Early 1965 Mustang HiPo 289 Special K code, Autolite 4100 series, from May 1964 and on, 1.12 venturi size carburetor, part number C4OF-AL, application manual transmission.  Recently rebuilt using a no longer available from Ford, Motorcraft carb rebuild kit.  Original venturi cluster assemblies, primary F and secondary BA, jets primary 51 and secondaries 70, brass float levels set to spec at 29/64.  Choke pieces new and plated.  Correct molded in choke stop and non-drilled and non-tapped holes. The top cover vent tube is also non-drilled.  Ready to install on your K code Mustang.  Please see pictures and ask questions.  A very nice carb.  $950.  Thank you.  Cory
Offline SFM6S1640
Re: Early 1965 Mustang HiPo 289 Special K code C4OF-AL
« Reply #1 on: June 02, 2011, 02:47:56 AM »
More pictures.
Offline SFM6S1640
« Reply #2 on: July 11, 2011, 03:33:58 PM »
The carb is sold.  Thank you.   Cory
