Author Topic: C4, 289 Pedal, trans carb linkages finish  (Read 869 times)
Offline TonyFio
« on: August 22, 2024, 07:36:43 PM »
I've been trying to put together how the various linkages between the accelerator pedal, the carburetor, the C4 transmission and the shifter should be finished. I'll list what I guess is correct and would appreciate the feedback of you experts out there. In searching other posts there have been different terminology for some parts, so I will use what I've found in the shop manual.
Transmission Manual Lever (bar from bottom console shifter to the trans control lever): Looks natural, maybe zinc plate with clear chromate?
Kick Down Lever Rod (from trans control lever to Bell Crank): Looks like zinc with clear chromate?
Bell Crank Assembly (carb rod pushes on this to activate the kick down): Natural? Zinc?
Carburetor Rod (from accelerator pedal linkage to the carb): Looks like zinc with clear chromate, but I've seen some photos of this as zinc with yellow chromate
Accelerator Pedal Linkage: Light phosphate and oil
Return springs: dark P&O?
Tony Fiorenza
65 Lux Coupe, SJ built, 5/65, owned since 1974
