Author Topic: Bellhousing paint overspray from engine application. 428 FE engines  (Read 1245 times)
Offline DaveF
Did bellhousings have any blue engine overspray on the front edge?
I?m curious about this. Thanks
« Last Edit: August 08, 2024, 03:16:51 AM by J_Speegle »
1970 Mustang Mach One
428 SCJ w/Drag Pak 3.91
Metuchen plant
Built 9/5/1969
Re: Did bellhousings have any blue engine overspray on the front edge?
« Reply #1 on: August 07, 2024, 08:55:29 AM »
are you asking about the car in your signature or small blocks & big blocks. the answer varies. a search here will yield the answer you are seeking.
Offline DaveF
« Reply #2 on: August 07, 2024, 11:47:34 AM »
I am asking about the car in my signature. Maybe I?m not good at searching, but I wasn?t finding much of an answer to my question.
Metuchen plant
Built 9/5/1969
« Reply #3 on: August 07, 2024, 12:46:51 PM »
  428 bellhousing was attached to the engine when it was painted so there is overspray.
Re: Bellhousing paint overspray from engine application. 428 FE engines
« Reply #4 on: August 08, 2024, 03:18:47 AM »
Changed the title to a title rather than a longer question and added your question to your original post  ;)
Want to also mention or remind those that will read this thread that we're discussing bell housings on manual transmission equipped cars just to keep the confusion down a bit.
Offline DaveF
« Reply #5 on: August 08, 2024, 10:38:02 AM »
Thanks for your help! I appreciate it!
Metuchen plant
Built 9/5/1969
