Author Topic: How to modify Gabriel front shocks to comply with ?driven exception? rules  (Read 2676 times)
Offline DaveF
A while back, I saw a post about how to modify Gabriel front shocks to comply with ?driven exception rules. It involved trimming them to a certain length as well as painting instructions. Now I can?t find it. Any help is appreciated.
1970 Mustang Mach One
428 SCJ w/Drag Pak 3.91
Metuchen plant
Built 9/5/1969
Guess your asking about newer Gabriels not ones from the 60-70's. Haven't seen or looked at newer fronts but would think that you need to remove any decals, and fill any stamping in the body of the front shocks. Check the upper mount since allot of newer fronts seem to use the same loop with the 57 stamped on the top and easy tell. Strip them of paint before you fill the markings and paint them semi-gloss black in the retracted position, with the lower bushings and retainers off and over the upper bushing.
Make sure the lower retainers and bushings are correct   as well as the upper retaining bolts
Nice thing is that fronts are harder to see once installed and rears are more difficult to fake.
Offline DaveF
Thanks Jeff. Do the side ?skirts? need to be shortened somewhat? I thought I remember reading that.
Metuchen plant
Built 9/5/1969
Not certain what your referring to as "Side skirts"
It is hard for many of us to keep up with every changing after market or reproduction parts. Working with original parts is what most of us are used to working with. With that said consequently if you post a picture of what you are working with it will then allow someone to make a suggestion of how to or at least advise to what the goal is supposed to look like.
Offline DaveF
I think that I was referring to the length of the outside tube. Side skirts certainly wasn?t a good reference. If I could get some shocks that are more correct, I would definitely be interested.
Metuchen plant
Built 9/5/1969
Did we move from front shocks to rears?
Often the owner tube on those for aftermarkets are attached differently today. Never measured the length that I recall
