Author Topic: 1967 GT mustang coupe Correct window winder handles  (Read 1698 times)
Offline Tiny
« on: July 28, 2024, 07:40:03 PM »
Hi all, can you please advise whether the window winder handles for both front and rear (Coupe) are with or without screws.  My coupe has a mixture of both so I am not sure which are the correct handles for a 67 Deluxe interior Coupe.  My inner door handles are screw type so I assume that is correct.
Many thanks
67 San Jose Built GTA 390 Coupe
C6, PS, A/C
Re: 1967 GT mustang coupe Correct window winder handles
« Reply #1 on: July 28, 2024, 07:55:36 PM »
Only the back windows (coupe and convertible) use set screws. The front window crank and door handle use a trim screw.
Offline Tiny
« Reply #2 on: July 28, 2024, 08:02:25 PM »
Thanks for the quick response.  When you say Set Screw, is that the Allan Key Head type screw? (Hexagon Head)
Some of the handles on my car have no screws at all.  they have a clip that holds them on between the handle and the door panel.  I assume they are off a later model.
C6, PS, A/C
« Reply #3 on: July 29, 2024, 12:33:20 AM »
Sometimes. Another "drive" used in that era for a set screw is a slot for a flat blade screwdriver. Do some homework and find out the part number. Use this forum's library.
KJKim
« Reply #4 on: July 29, 2024, 12:37:16 AM »
No clips used on any 67s. Yes set screw = Allan key head.
Offline Tiny
« Reply #5 on: July 29, 2024, 04:49:02 PM »
Thanks everyone.  great advice
C6, PS, A/C
