Author Topic: Early 66 C4ZE Radiator Wanted Manual Trans  (Read 866 times)
Offline hertz350
« on: July 23, 2024, 01:44:58 PM »
Looking for a rebuildable original 66 Mustang radiator for manual transmission. I prefer the Modine radiator for San Jose built cars.
« Last Edit: August 02, 2024, 01:04:50 AM by hertz350 »
Re: Early 66 3 Row Radiator Wanted
« Reply #1 on: July 23, 2024, 02:13:07 PM »
Looking for a rebuildable original 66 Mustang 3 row radiator.
Is it safe to assume it needs to be for a automatic?
« Reply #2 on: July 23, 2024, 02:15:04 PM »
What range of date code is needed?
Offline hertz350
« Reply #3 on: July 23, 2024, 09:06:27 PM »
This is for a 4 speed. Car was scheduled to be built September 17, 1965.
Offline CW4macret
« Reply #4 on: July 24, 2024, 11:37:08 AM »
Not the correct date code but, unless doing a thoroughbred, it is correct application and will be OK for Concours.
https://www.concoursmustang.com/forum/index.php?topic=26156.0
Mac
64.5, 5F07D
66 Convertible 6T08T
71 Mach1 429CJ 1F05J
01 Coupe
05 GT
08 GT500
14 GT500
« Reply #5 on: July 24, 2024, 11:58:10 AM »
I would add that ID numbers are not relevant in all but thoroughbred however placement of ID can be relevant. Better that they disappear then be in the wrong spot and wrong type (stamped vs. raised). In this case if I was using a similar radiator I would bondo over and make Dearborn metal stamped ID disappear . Not necessary but I would solder on a AMK metal ID tag to better complete the illusion. That is if you want to totally eliminate the possibility of a minor deduction or at least a write up in a similar scenario.
« Reply #6 on: July 24, 2024, 12:04:41 PM »
Of course my statement was in regards to a Dearborn or Metuchen radiator being used in a San Jose car entered in concours . I assume a Shelby application in this case given the OP's avatar name and NO other information that would be relevant to the wanted part.
Offline hertz350
« Reply #7 on: July 24, 2024, 12:50:59 PM »
Hi Bob. Thanks for all the research and information. This is not for my '66 Shelby but for my look a like car. This car has AC and that is why I want a 3 row radiator. I am hoping to find one also with correct part numbers or I will use an AMK tag.
