Author Topic: 68 Metuchen Accelerator Gas Pedal Screw 9873  (Read 3651 times)
Re: 68 Metuchen Accelerator Gas Pedal Screw 9873
« Reply #15 on: July 19, 2024, 05:34:08 PM »
Side by side,  the Scott Drake part (top) is very different from the one I pulled off my car (bottom). The head on the SD part is thinner,  the threads are longer,  and there is the groove on the threads.
Like so many reproduction but better now then in the past, its likely that the reproduction was copied from a later service part purchased in the 80-90's
Thanks for the side by side
Offline dkknab
« Reply #16 on: July 19, 2024, 05:34:49 PM »
Out of curiosity, what type of drive is on the lower screw, the one you "damaged"?
Phillips
I wish I had some patience to figure out where the bolt might have rusted to the pedal and would have not destroyed it.  Oh well.  Maybe I need to get another 68 , I'll know better next time.
« Last Edit: July 19, 2024, 05:52:39 PM by dkknab »
David Knab
289 2V, AT, PS
Nugget Gold Interior
« Reply #17 on: July 19, 2024, 07:00:06 PM »
That looks like a Phillips (or a"Posidriv" type -  I almost always use the same type X-Rec screwdriver on either). The drive shown in the NPD drawing looks like a six point, like an Allen screw or one with "points" around the hex (the name escapes me). What you had installed was the 64-67 type, not the C8OZ-9873 (it's missing the "-A" according to the MPC). The NPD screw "may" be the Concourse correct style.
« Reply #18 on: July 19, 2024, 07:06:16 PM »
Did a little search and came up with this original gas pedal and retainer
Not making any claims just posting it for consideration and discussion  :)
Offline dkknab
« Reply #19 on: July 19, 2024, 07:28:38 PM »
Apparently there was a change as of April 25, 1968 which my car is before. That's specified in the NPD listing. So yes concours for cars after April 25 1968 possibly,  but not for me.
David Knab
289 2V, AT, PS
Offline dkknab
« Reply #20 on: July 19, 2024, 07:30:56 PM »
Looks like mine,  the threads are about the same length as the unthreaded section unlike the Scott Drake part where the threads are longer than unthreated section.
David Knab
289 2V, AT, PS
Offline TLea
« Reply #21 on: September 21, 2024, 09:31:53 PM »
I know this is late to the game, but hopefully I had some clarity to this. I have seen both silver and phosphate screws used on original cars from 65 through 68. The majority of them have been phosphate. The one you show from the NPD catalog with the C8 part number is actually used in 69.
