Author Topic: How to get the correct paint formula with modern components  (Read 1401 times)
Offline DaveF
My car doesn?t have any of the original paint on it so I can?t match it that way. I am trying to match paint code. G, which is medium lime metallic. Does anyone have a modern formula for this paint?
1970 Mustang Mach One
428 SCJ w/Drag Pak 3.91
Metuchen plant
Built 9/5/1969
Offline Coralsnake
Re: How to get the correct paint formula with modern components
« Reply #1 on: July 17, 2024, 08:16:28 PM »
Dave, unless your car has been chemically dipped I am willing to bet you have some original paint.
Regardless, the paint companies should be able to convert the old codes to the newer formulas.
The codes for medium lime poly aka medium Avacado are easy to find
The old Dupont code is 5176
You will probably want to see what brands your painter is willing to spray. Companies like Dupont/PPG are still around in some form
« Last Edit: July 17, 2024, 08:21:20 PM by Coralsnake »
« Reply #2 on: July 17, 2024, 09:01:48 PM »
Check out the protected back side of things like headlight buckets, end caps as such and pray that the painter was generous and applied a decent coat of paint in one of these areas.
Offline DaveF
« Reply #3 on: July 22, 2024, 12:33:18 AM »
I?m certain that none of the original paint remains. During its years as a race car, the entire car was bright red. When the car was restored, all of the red paint was meticulously removed and the car was respirated the wrong shade of green. Now we are trying to straighten that out.
Metuchen plant
Built 9/5/1969
Offline jmlay
« Reply #4 on: July 23, 2024, 10:13:09 PM »
1970 Medium Lime Poly is PPG 2152. Should be able to go to any PPG supplier and get the color mixed.:
Mike
1969 Mach1 428 CJ Ram Air
San Jose
Scheduled Build: 1/2/1969
Actual Build: 1/3/1969
Released: 1/8/1969
Offline DaveF
« Reply #5 on: July 23, 2024, 11:51:51 PM »
I appreciate that. Thanks!
Metuchen plant
Built 9/5/1969
