Author Topic: Air cleaner base for 70 R code  (Read 1322 times)
Offline DaveF
« on: July 02, 2024, 12:12:09 AM »
I am looking for an air cleaner base for my 70 R code. When I look online, all of the ones that I can find are either for a Q code, or a 1969 R code (with metal pcv elbow). Is there anywhere that I can get one for a 70 R code air cleaner base?
1970 Mustang Mach One
428 SCJ w/Drag Pak 3.91
Metuchen plant
Built 9/5/1969
Re: Air cleaner base for 70 R code
« Reply #1 on: July 04, 2024, 12:35:48 AM »
You can buy a air cleaner from another application with the same elbow, remove it and add it to the base needing repair or as some people do, faking an original
Offline DaveF
« Reply #2 on: July 05, 2024, 11:35:44 PM »
I have seen the plastic elbow for sale. Does it mount in the same place as the metal one?
Metuchen plant
Built 9/5/1969
Offline 70cj428
« Reply #3 on: July 10, 2024, 01:40:04 PM »
Hi Dave, Just FYI, The 1970 428 air cleaner base is a different stamping than the 1969 "R" code base. There are other bases that can be converted with some work to a very convincing 69 base (1967 Thunderbird)  but nothing common that I'm aware of that you can use to "make" a 1970 base that's even close to concours correct. Aside from the elbow changing from steel to plastic, the 70 bases have a large area stamped into the base for additional clearance around the throttle cable/kickdown rod area. If your not concerned about correctness, a 69 "R" code base or a converted Thunderbird base will work. Real 1970 "R" code bases or shakers turn up occasionally, If you come asross a decent one, I'd highly recommend biting the bullet and buying it..... Check out the air cleaner section here to see the difference. Hope this helps, John
https://www.428cobrajet.org/id-main
Here's the area on a 70 base that makes it unique...
« Last Edit: July 10, 2024, 01:50:48 PM by 70cj428 »
« Reply #4 on: July 23, 2024, 08:06:02 AM »
And also the 70 california evap hole and blue plug on the rh side.
