Author Topic: Why do I have to sign in every time I visit this site  (Read 2237 times)
Offline DaveF
« on: July 02, 2024, 12:07:31 AM »
In spite of checking the forever tab (or any other time period tab), I have to sign in each and every time I visit this page. Am I doing something wrong? Thanks
1970 Mustang Mach One
428 SCJ w/Drag Pak 3.91
Metuchen plant
Built 9/5/1969
Offline sah62
Re: Why do I have to sign in every time I visit this site
« Reply #1 on: July 02, 2024, 07:39:36 AM »
Perhaps your browser isn't saving a small file (known as a "cookie") when you go through the login process. Your browser settings can let you see all of the saved cookies. Do you know how to find that information? If not, which browser are you using on what type of device (PC, phone, etc.)?
Scott Hollenbeck
2019 Lincoln MKZ 3.0T AWD
2003 Mercury Marauder 300A
(more non-Ford stuff)
Offline DaveF
« Reply #2 on: July 05, 2024, 11:46:15 PM »
Thanks for your help. I?m using Safari on an iPhone.
Metuchen plant
Built 9/5/1969
Offline sah62
« Reply #3 on: July 06, 2024, 08:59:41 AM »
Try this: login to the forum using Safari on your iPhone.
On the phone: go to Settings->Safari->Advanced->Website Data. You should see an entry for concoursmustang.com. If you do, the cookie has been set and you should be able to close the browser and come back to the site without logging in again. If there's no entry, the cookie isn't being set.
Look at Settings->Safari. Is "Block All Cookies" enabled? If so, turn it off and try logging in again. Is JavaScript enabled? If not, turn it on and try again.
Scott Hollenbeck
« Reply #4 on: July 07, 2024, 01:39:13 AM »
Also, if you're using the private browsing option of Safari, it won't save site info.
Offline DaveF
« Reply #5 on: July 08, 2024, 01:14:59 AM »
I followed your advice and got it straightened out! Thanks!
Metuchen plant
Built 9/5/1969
