Author Topic: 1966 Tail Light Housings  (Read 2102 times)
Offline Twilight65
  • Gold Level Subscriber
« on: October 30, 2009, 07:48:16 PM »
Can someone tell me the correct hardware to use when installing the tail light housing to the tail light panel. When I was dismantling, I had one side that just had the stamped nuts on all four studs, while the other side had stamped nuts on the two bottom studs and stamped nuts with an angle metal piece on the two top studs. My 65 is the latter with angle pieces on the top two. Had me wondering which is the correct way. ???
Dave
Re: 1966 Tail Light Housings
« Reply #1 on: October 30, 2009, 08:08:41 PM »
you should have the angled pieces on the top of both housings.
Offline Twilight65
« Reply #2 on: October 30, 2009, 11:33:08 PM »
Thank you Sir. Now I'll need to find a couple of replacements.
Dave
« Reply #3 on: October 31, 2009, 11:01:40 AM »
va mustang sells those.
