Author Topic: 1967 manual steering ball nut  (Read 701 times)
Offline mtinkham
  • That'll be easy
« on: June 10, 2024, 01:59:24 PM »
I am in need of the ball nut that engages with the sector shaft. The ball nut that I took out of my steering box has a broken tooth. My steering box tag is difficult to read - very lightly stamped. If I can get a meaningful number, I will add to this post. But I believe this box is the standard 19:1 ratio, 1-1/8" sector shaft variety for my signature car.
Re: 1967 manual steering ball nut
« Reply #1 on: June 10, 2024, 02:23:33 PM »
do a search here for 'chokostang' he rebuilds those quite nicely.
Offline mtinkham
  • That'll be easy
« Reply #2 on: June 11, 2024, 02:10:17 PM »
Thank you for the lead.
Offline mtinkham
  • That'll be easy
Re: 1967 manual steering ball nut - (no longer needed)
« Reply #3 on: June 13, 2024, 01:58:14 PM »
I reached out to Chockostang and Dan calls this item "the rack". Manual identifies it as a ball nut, though. Anyway, either between the spare steering box that I had in inventory or Chockostang, I should be all set with this item. Thanks.
« Reply #4 on: June 13, 2024, 02:34:05 PM »
To help with future searches, using the attached diagram, what is the Ford basic part number that you are referring to?
« Reply #5 on: June 13, 2024, 06:05:22 PM »
I never heard of it either -- until now. From the Repair Manual.
