Author Topic: Wiring Harness Fabric Sleeve  (Read 6613 times)
Offline Alpha1946
« on: May 23, 2011, 12:20:51 PM »
Does anyone have a source for the fabric sleeve that covers the wire harness from dash to tail lights for 64 1/2 Convertible built in June 1964 in Dearborn?  Thanks for any suggestions.
64.5 Wimbledon White Convertible
Dearborn June 1964
289
4 speed
76A   M   42   04F   55   1 5
5F08D156472
Re: Wiring Harness Fabric Sleeve
« Reply #1 on: May 23, 2011, 03:11:34 PM »
It is woven on over the wires, have not found a source that sells a replacement covering.
Offline Murf
« Reply #2 on: May 23, 2011, 03:52:30 PM »
At one time Ken Rubin at Alloy Metal products would recover your tail light harness with the correct material.  He is no longer with us and I do not know if the folks running his company now will still offer that service.  Pat White in Texas also could duplicate that covering, but check on his past performance and then decide if you want to use his service.  It is cheaper and probably better to purchase a reproduction from Alloy Metal Products and replace your original.  It is almost impossible to tell it is a reproduction other than your new one will be in perfect shape.  There is, as far as I know, no covering that can be installed over your harness that even resembles the original.
John Murphy
« Reply #3 on: May 23, 2011, 05:33:31 PM »
Jim Thayer was Ken's business partner and took over Alloy when Ken passed away.  Jim did tell me back a few years that he would do an occasional harness restoration, but it's not something they normally offer (as far as I know.)
« Reply #4 on: May 23, 2011, 09:46:42 PM »
There's more to this than meets the eye.  The original woven material was made out of cotton, and OSHA (I think that is them) banned it for this use due to its flammability.  I've contacted several wire and loom manufacturers and they will not provide cotton looming.  The replacement looming that I have looked at doesn't appear close to the original.  The other issue is that the looming is first applied to the raw wires, and then the connectors are molded onto the pins.  If you look carefully, the original looming is worked back inside itself where wires break out.  I've tried once to cut the wires so I could slip the looming back on and then resplice the wires with the looming covering the splice---couldn't do it.
One person went to RI Wiring (http://www.riwire.com/) and had his tailight harness re-loomed.  I did not find out how much it cost, but I'm sure it was at least $200 if not substantially more.  http://www.homeprofasteners.com/index.php?route=common/home is another source for asphalt-impregnated looming, but it is too stiff to use on anything but a single wire where you can remove the pin from the connector to slip the sleeving over the wire.
Offline e093116
« Reply #5 on: May 23, 2011, 10:11:48 PM »
I've wanted to buy a used braiding machine to do this sort of thing but haven't found one yet for a price I'm willing to pay.  I believe the used market is strong so I may never find one...
Some machines, pictures here:
http://www.gladdingbraid.com/marketplace.php
Might be able to get this same place to re-braid your harness or make a slip over cover for you, although you'd probably have to specify materials, etc. or provide a good sample:
http://www.gladdingbraid.com/harness_braiding.php
65 San Jose Fastback, May 15 build date
Offline Alpha1946
« Reply #6 on: May 25, 2011, 07:41:52 PM »
I would like to thank all of you that replied and for your help.
Dearborn June 1964
289
4 speed
76A   M   42   04F   55   1 5
5F08D156472
Offline Anghelrestorations
    • Anghel Restorations
« Reply #7 on: June 24, 2011, 06:22:18 PM »
There is three companies I have come across out there that will take your original wire harness and wrap a new cloth covering on for you.  Its not something you can purchase and do yourself properly....its actually woven on and around your harness with a special machine.  Ideally you would want to give them a sample they can match for color and weave pattern.
Rhode Island Wiring Service:
Narragansett Reproductions:
http://www.narragansettreproductions.com/wiring-harness.html
YNZ Yesterdays Parts:
http://www.ynzyesterdaysparts.com/contact_us.htm
Turn around is typically 2 to 4 weeks and they charge about $5 a foot plus a setup charge and if they need to take your old stuff off they will charge for that as well.
Marcus Anghel
www.anghelrestorations.com
« Reply #8 on: October 03, 2018, 12:50:31 PM »
I just contacted Rhode Island wiring and spent a pleasant 15 minutes talking about Ford wiring.
I supply a sample of the loom and they match it. Some coverings had cotton, indicated by a thicker strand(s) running back on the harness.
Today's cost is a setup fee of $7 (seven dollars) and $4.50 a foot for the cover.
If they have to remove the cover it's at a dollar per hour rate. They suggested I remove it and re-tape the harness at the factory locations since by now the original friction tape is old and brittle.
Sounds like a deal.
« Reply #9 on: October 03, 2018, 01:52:17 PM »
Be careful what covering they weave over it. The black covering seems to be most common but it is not like original factory and stands out so much as wrong compared to original it may be points deducted. I understand that there are some color alternatives. Just stay away from black which is what typically comes on the repro wiring harness's.
« Reply #10 on: October 03, 2018, 04:33:06 PM »
I've seen Rhode Island Wiring harnesses (a 53 Plymouth Cranbrook Convertible) and was impressed. They specialize in 1960 and earlier cars, but they seem interested in later years to expand their product line. In all transactions with an unknown vendor, get samples, get referrals, get prices. I've used many of their component parts - contacts, splices, sleeves, etc.
« Reply #11 on: October 03, 2018, 06:02:08 PM »
I was going to send the vendor of choice my Ford harness and have it covered. They also requested a sample.
However, in another moment of "huh, I always thought it was ..." I did think it was lighter black and really faded.
But my original harness is khaki green and hunter green (says the wife who deals with colors a lot). The harness out of my parts car is the same. The colors alternate in bands lengthwise along the harness.
What colors have you guys found on 67 SJ cars? Since most of these vendors tend to work on older cars, is there an earlier Ford that used this same color weave (whatever it may be)?
Offline midnite cruiser
  • midnite cruiser
« Reply #12 on: July 15, 2019, 11:33:05 AM »
Apologies for the later post but I also have the 64.5 convertible wire conundrum. Plus there seems no real closure.
Targeting Concours Driven, and I want to get on the road.
I see where NPD offer fabric wrap in two styles. "OE" and "Self wrapping OE appearance"
Each of these look to be impregnated with some tar like material
Is there experience out there with either of these? Mostly concerned OE type will mean a wire cut, tugging on of the wrap, and splice. (I would try to do this mid run rather than terminal). Dealing with aforementioned mid-run, through-weave splits and connections sounds impossible- more of a stop-wrap-restart wrap?
The "self-wrapping" likely has a slit but I am unsure how well it closes. Soft heat gun?
How do judges even view this re-wrap. Am I better off leaving my ratty but 90% covered harnesses in place? (most still have Fomoco paper tags)
Opinions?
JWhite
64.5 D code convert. / C4 / AC / PS / RP
« Reply #13 on: July 15, 2019, 02:53:18 PM »
Opinions?
I suppose you need to be more specific on which wiring harness you are referring to. The taillight harness for instance has a weaved thread material .The engine harness is wrapped in a black tape. In concours driven most likely a color difference in the weave which has been discussed previously in other posts like the repro black weave vs original dark hunter green would be over looked. The condition of the weave would be most important in that situation. The black wrap used on the engine compartment harness's would need to be wrapped with a near factory like precision and workmanship and there should be no deduction. The repro black wrapped harness's are typically acceptable in that instance. Most re tape wrap the original engine harness after making repairs and cleaning. Of course if one doesn't want to go to the trouble or they feel the harness is damaged too much then a new repro is just a 1 800 number away.
« Reply #14 on: July 15, 2019, 04:28:27 PM »
If you really, really, really want the original wrap you have to source the threads and send enough of the two different color threads to RI Wire.
Good luck finding the right colors as dark hunter green is not a stocking color.
Also, there is a size and number of "winds" to each thread.
BTW, the weave/wrap can applied after the connectors and plugs are already on as it's not a sleeve but a merry-go-round weaving machine where you pull the wire up through the center of the merry-go-round and pull out any wires you don't want in the wrap. The operator starts/stops the machine to do the pull-outs.
Here is a pic of what I believe to be a very close approximation of the correct color after RI Wire did my rear loom.
