Author Topic: Mar 1966 Metuchen Undercarriage  (Read 1539 times)
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« on: May 23, 2011, 10:45:31 AM »
As I continue to clean up the underneath of my car, I have the opinion that both times the car was repainted, the painter taped off the rocker moldings and just painted from there up.
Because of that, my red-oxide factory epoxy is in very good condition.  The only thing I actually REMOVED was the bead of black seam sealer in the inner corner of the pinch weld.
I thought a few of these pictures may be of value to those who keep a library of photos of unrestored cars.  In the pictures, you can clearly see many details.
Among them:
*  Red was sprayed mostly from one side because at the buck-skid attachments there is a hard circular line on one side and a fogged pattern on the downwind side.
*  Even though this was a "DARK" (Nightmist) car, blackout was clearly applied.
*  Very little to almost no Nightmist overspray anywhere and very little blue paint was applied below the moldings.  This indicates the painter was spraying downward.
*  Some kind of grayish primer/sealer was used below the moldings and between the blackout and red-oxide??.  Not sure how it got there?  I THINK??? it's original.
66 Metuch Conv
Nightmist, Std Blu Int
Offline Pete Bush
Re: Mar 1966 Metuchen Undercarriage
« Reply #1 on: May 23, 2011, 02:56:30 PM »
Bryan,
Keep the pictures coming - from every angle. They'll help immensely as I rebuild my undercarriage!
« Reply #2 on: May 23, 2011, 06:39:54 PM »
So that they can be labeled and filled are these from your convertible (VIN at the bottom of your post) ?
Guess (by the pictures and your written words) that the painter was pretty lazy or one of the older guys that didn't bend over well or put too much effort on this car - this is different from the last two cars I took photos of from that year and plant
Great to see another (get one every so often out here that escaped early in its like) solid NJ cars. So rare it seems
Thanks for sharing
Offline bryancobb
  • 2009 Ridn' Around
« Reply #3 on: May 23, 2011, 06:44:00 PM »
Yes Jeff.  My car in signature.
66 Metuch Conv
