Author Topic: Shaker vacuum line  (Read 3021 times)
Offline grabberblue
Shaker vacuum line
« on: May 28, 2024, 11:53:22 PM »
Might anyone know where to acquire the blue stripped vacuum line that runs from the tee to the vacuum canister on the back of the mid-plate? What's generally available is for the flat hood air cleaner and that line is 22". It's definitely to short, any help would be greatly appreciated.
Thank you,
Dan
Offline fla2005
Re: Shaker vacuum line
« Reply #1 on: May 30, 2024, 12:09:17 PM »
Usually in the vacuum line kit available from parts companies such as NPD.
Offline RocketScientist
« Reply #2 on: May 31, 2024, 02:10:31 AM »
Dan, I found the kits to be random - one had the line too short and the other just right and there was nothing on the packaging to tell the difference.
Brad
« Reply #3 on: May 31, 2024, 11:22:32 AM »
Thank you,
Dan
This kit is labeled "Distributor vacuum lines" but it includes all the vacuum hoses. [size=78%]https://www.martiauto.com/itemselection.cfm?item=DVK-1&selecteditem=yes[/size]
Offline grabberblue
« Reply #4 on: June 01, 2024, 01:10:48 AM »
Thank you for the replies. I contacted Jack Brooks at Dead Nuts On and the kit he sells the blue strip hose is 31" long. More than enough for a shaker air cleaner. I purchased the kit and I'll post the fitment results as soon as I get it.
Dan
Offline grabberblue
« Reply #5 on: July 05, 2024, 11:09:00 PM »
The kit that Jack sells (DNO), the blue striped vacuum hose has more than enough for a shaker hood. I installed it and there was left over that I had to cut. Just wanted to bring closure to my post.
Dan
