Author Topic: NOS C7ZZ-3494-A 1967 Mustang Power Steering Hose  (Read 1335 times)
Offline Snydly289
« on: May 25, 2024, 01:45:18 PM »
C7ZZ-3494-A (engineering number stamped C7ZA-3494-B)
This is a one year only power steering hose that connects to the pump high-pressure hose at the insulator and then routes down to the valve body.
The Ford MPC indicates this hose was used up to June 19, 1967 production but actual changeover date on the production line varied due to production line stock. If your car's production date is close to this change over date you should check your control valve port size. If your car was built after 6-19-67 you will need the larger port C7ZZ-3494-B hose. (This information was attained from Dead Nuts On Concourse Restoration Website)
This hose has the smaller 7/16 inch wrench size control valve fitting for the early control valve, not the 1/2 inch wrench size control valve fitting used on the later cars with the larger valve.
This hose has the small FoMoCo logo die stamped next to the engineering number, reproductions don?t. From my research, this hose is correct for early 67 HiPo 289 and 390 and early all GT350/GT500 cars with the smaller control valve.
Asking $225 SOLD plus shipping
« Last Edit: May 27, 2024, 10:17:18 PM by Snydly289 »
65 K Code Fastback -5F09K325XXX, Oct. '64, Vintage Burg, Rally Pac, Arvinode Exh, lots '64 items
66 A Code GT Coupe -4 speed, bench Seat, P/S, A/C, Rally Pac, handling package, 8 track
66 A Code Fastback -Built 302, 66 S2MS Intake, WC T-5, 4-wheel Wilwoods, locking 9"
66 T Coupe
65 T Code Fastback
Offline Snydly289
Re: NOS C7ZZ-3494-A 1967 Mustang Power Steering Hose
« Reply #1 on: May 25, 2024, 01:46:06 PM »
Additional pics
66 T Coupe
65 T Code Fastback
Offline Snydly289
« Reply #2 on: May 25, 2024, 01:47:04 PM »
Additional pics
66 T Coupe
65 T Code Fastback
« Reply #3 on: May 25, 2024, 09:04:56 PM »
This hose has the smaller 7/16 inch control valve fitting for the early control valve, not the ? inch control valve fitting used on the later cars with the larger valve.
This hose has the small FoMoCo logo die stamped next to the engineering number, reproductions don?t. From my research, this hose is correct for early 67 HiPo 289 and 390 and early GT350/GT500 cars with the smaller control valve.
Asking $225 plus shipping
Not for just early but all GT350/500
Offline Deuce
« Reply #4 on: May 26, 2024, 06:20:49 PM »
Believe the early hose has a 1/4" control valve fitting.  The later hose has a 5/16" control valve fitting.
Deuce
« Reply #5 on: May 26, 2024, 08:27:13 PM »
It's a 7/16" wrench size versus a 1/2" wrench size. He has the early one.
Not sure if a GT-350 would use the big block PS pressure hose. My guess would be no.
« Reply #6 on: May 27, 2024, 05:32:35 PM »
Guess again.  ;) 1967 GT350/500 use the same C7ZZ-A control valve hose. 68, 69 and 70 GT350/500 use the larger control valve hose.
Offline Snydly289
« Reply #7 on: May 27, 2024, 10:17:30 PM »
Hose has been sold
66 T Coupe
65 T Code Fastback
