Author Topic: Parking brake cable from pedal removal  (Read 645 times)
Offline 88s69Mach1
« on: May 14, 2024, 10:02:55 PM »
Howdy! At a total loss as to how to remove the cable from the parking brake pedal that goes through the firewall!! The cable seems to just be press fit into the hole with rubber around the cable housing but I can't seem to get it to budge... The cable is disconnected from the pedal and from the rear cables that go to the drums...
Hopefully someone can help me out a bit with this one....  Thanks!!!
1969 Mach 1 M code, Indian Fire red, 4 speed close ratio trans, 3.25 Trac Loc, P/S, P/B, Sport  seat, original Ca. black plate.
San Jose built, 11/08/68. Four hole hood!
Re: Parking brake cable from pedal removal
« Reply #1 on: May 15, 2024, 09:01:37 AM »
it's just stuck. looks like the sheet metal has sliced into the rubber.
Offline 88s69Mach1
« Reply #2 on: May 15, 2024, 12:13:12 PM »
Okay!  Thanks.. I'll. just have to eat some spinach and try and pull harder!!  😂
